Author Topic: Microcat hopper mechanism  (Read 5400 times)
inertia
« on: November 22, 2015, 10:35:09 am »
I have a customer who is re-equipping his Microcat with a P94 etc. He describes the hopper release as "a wire which contracts when a + and - connection is made". This doesn't sound correct to me, but I have no better idea of how the hoppers on this boat work and - more particularly - what current they draw when doing so.
I've advised him on how to measure the current but I'm not at all convinced he understood or that he has a multimeter! Can anyone assist, please?
Dave M
JimG
Re: Microcat hopper mechanism
« Reply #1 on: November 22, 2015, 01:32:11 pm »
It sounds like a memory metal wire. This will change length with temperature so the addition of power will heat it up as it is a resistor.
Jim
Dundee Model Boat club
inertia
« Reply #2 on: November 22, 2015, 04:43:03 pm »
Jim
Metal generally expands when it heats up, doesn't it? It would be very slow to react in any event. I find it a bit hard to believe that the manufacturers of a bait boat would resort to fancy technology just to open a hopper full of boilies or live bait. Mr Angler wants to dump the bait at the flick of a switch, right over the spot where he suspects Mr Carp is hiding. He won't want to wait for a wire to get hot and shrink/expand or whatever.
Having given it some further thought it sounds more like a wire catch operated by a solenoid to me. I wonder if anyone can confirm that from actually owning and operating one?
If not we may never find out... :o
DM
Big Ada
« Reply #3 on: November 22, 2015, 05:37:13 pm »
Could it be as simple as the wire moving by the action of a servo?.
« Reply #4 on: November 22, 2015, 08:51:20 pm »
PM sent Dave
Captain fizz
« Reply #5 on: February 20, 2016, 06:14:26 pm »
That sounds the most likely.
Stockmeister
« Reply #6 on: March 03, 2016, 06:01:16 pm »
Hi Guys
Old thread i know, but I believe its a product called Flexinol that Angling Technics use on their hopper release systems.
http://www.musclewires.com/home.php
http://www.merg.org.uk/merg_kitlocker/info-sources/67.pdf
I've looked into retro fitting it on my bait boat, but gave up  {:-{
dave_saddler
« Reply #7 on: March 12, 2017, 01:43:52 pm »
I've got one of these I am converting to 2.4 ghz after the 40hz radio packed up. I have put two d sized batteries together and this opened the hoppers in around the same time as they did. Only trouble is I don't know how to reduce the input from the 12v and then operate using the tx/rx.
Any ideas??
« Reply #8 on: March 12, 2017, 04:04:09 pm »
ACTion switcher that will work for you
