Author Topic: Billings Boats St.Canute tug  (Read 21225 times)
polobeer
« on: July 30, 2007, 10:47:17 pm »
Dear Mayhemmers,
Me again with yet another question! Could anyone give me advice about building the Billings Boats St.Canute tug (the plank on frame bit especially). I've never built this type of kit before but I feel confident that I could do it. If anyone has any advice/photos/experiences I'd be very interested to hear.
Simon  ??? ::) ???
slewis
Re: Billings Boats St.Canute tug
« Reply #1 on: July 30, 2007, 11:09:58 pm »
Simon I think you are looking more for how to plank on frame advice than how to build different models ? Am I right ?
Shane
polobeer
« Reply #2 on: July 31, 2007, 09:27:21 am »
Dear Shane,
Thanks for your message! In answer to your question, yes I am looking for assistance with plank on frame construction, but more specifically, I would like to hear about experiences with regards to the subtle aspects of this particular model.
Best wishes
Simon  ;)
Captain Povey
« Reply #3 on: July 31, 2007, 12:27:03 pm »
Hi Simon, I built the St Canute about a year ago and there were no particular problems apart from trying to work out the shape of the stern around the prop tube area. I resorted to using filler to get what I thought was the right form. I took a lot of time over the planking and only did a few at a time per side per evening. There is a good illustration and information on this site on the 'Build a Bismark' thread by Martin. It is quite a small model so there is not much room for any extras such as a sound module and speaker. Decide early on if it going to be powered as converting it afterwards would not be easy.  There were some small parts missing from my kit but I was able to replace them by making them on my lathe. The lathe was also useful for getting the parts of the funnel to fit. I also glazed the portholes bu using them as the punch on the plastic sheet over a soft piece of wood. The following are some pictures of my nearly completed model and as you can see it is quite detailed. I must confess that I did not put thread between the deck planks to simulate caulking as I am a bit lazy. Cheers Graham. :)
Captain Povey
« Reply #4 on: July 31, 2007, 01:18:53 pm »
Hello again Simon. The following are some pictures of the St Canute internals from which you can see the planking and one of her sailing at the Model boat Mayhem weekend. Cheers Graham  :)
polobeer
« Reply #5 on: July 31, 2007, 02:50:07 pm »
Dear Graham,
What a lovely model you've made! It looks superb! Many thanks for your kind assistance here - the information and photos you have provided will be invaluable. It was the stern area of the hull which most concerned me as it must be quite tricky getting the lines/profile just right.
With best wishes
Simon  :D :D :D
Captain Povey
« Reply #6 on: July 31, 2007, 04:49:48 pm »
Dear Simon, I am happy to have been be off assstance. If you do decide to go ahead with this model and I can be of help let me know. Cheers Graham. :)
RickF
« Reply #7 on: July 31, 2007, 05:49:33 pm »
Simon,
Will you be building "upside down" (keel uppermost) or "right way up". Either way, make sure you use a good firm building board. Get the keel blocked and screwed straight and vertical, then glue the frames in square. Leave plenty of time for the glue to harden before beginning planking.
Try and plank evenly - corresponding planks on each side of the hull. Once again, leave plenty of time for the glue to harden. DON'T RUSH THINGS.
There are several examples of plank and frame builds on the forum, including my own modest effort (Torpedo Boat 80). Everybody has their own way of doing things and most of them work! Good luck.
Rick
polobeer
« Reply #8 on: July 31, 2007, 07:31:32 pm »
Dear Rick and Graham,
Both of you have been very helpful indeed, so much so, that I now feel confident enough to have a crack at this attractive tug kit. I really feel the prototype stands out from the crowd with its "unusual" shaped ice breaker bow and quaint livery. One question I forgot to ask was, are there various options for covering the bare wooden hull once sanded, etc to water proof it and protect the wood? If so, which option would be the "easiest"? You will be the first to see my attempts at building the kit! Many thanks to you both, and if I could ask you for advice (should I get stuck in the future), that would be great.
With best wishes
Simon  ;) ;)
Captain Povey
« Reply #9 on: July 31, 2007, 11:21:10 pm »
Hi Rick, With this kit the keel is in two parts each half of which is nailed to a board before adding the formers so there are two halves to plank and I started the planking from the deck line down to the keel. It is very important to get the two halves aligned before gluing them together to form the complete hull.
Simon I relied on glue, filler, primer and paint to seal the hull but also lined the inside with nonails adhesive.. Others on this site have suggested otherways of sealing hulls but so far the planking has not moved and she has not sunk or shown signs of taking on water. Good luck with your build. Graham.  :)
RickF
« Reply #10 on: July 31, 2007, 11:33:05 pm »
Graham,
Interesting way of doing it! As I said, "everybody has their own way of doing things and most of them work". I have never considered splitting the hull longitudinally, but I can see the logic behind it. Food for thought......
Simon,
Good luck with the build - keep us posted and take some photos. With my hulls, once they are planked, I give the INSIDE a thick coat of two-part resin - I use Z-poxy,which is model aircraft stuff - and use sanding sealer on the outside, followed by primer, rubbing, more primer,more rubbing and so on.
polobeer
« Reply #11 on: August 01, 2007, 09:38:00 am »
Many thanks again to you both! I will definitely take photos whilst constructing the model and post them on the forum. The beers are on me fellas!
With best wishes
Simon  :)
Captain Povey
« Reply #12 on: August 25, 2007, 11:49:16 am »
H Simon, Following up your pm I am posting some pictures of the inside of the St Canute with all the stuff loaded ready for sailing. I hope they are of some help. I will post a copy of the plans next week. Sorry for the quality it was the best I could do with the equipment I have. Cheers Graham. O0
polobeer
« Reply #13 on: August 26, 2007, 10:22:36 am »
Dear Graham,
Your internal photos of St.Canute are excellent and very helpful - Many thanks again! Attached are two pictures of my St.Canute just after I won it on Ebay. As you can see it needs a fair amount of work to complete. I've started restoring the model and the third picture shows the first stages of this process, the first coat of green paint (after I gave the boat a thorough cleaning)! Apart from adding missing details and r/c equipment, the hull needs water proofing on the inside as well (which I've been busily working on). I will remove the old "St.Canute" name stickers that can be seen in the photos and paint the name on by hand, plus add the "missing" patch of black paint on the bow. As I progress I will post more photos.
Best wishes, Simon  :D
Captain Povey
« Reply #14 on: August 27, 2007, 08:15:58 pm »
Hi Simon, Thanks for posting the photos of your St Canute. I think she will clean up very well as it looks as if very few parts are missing. So with a winch, rear raised deck and a bit of rigging she will be complete. Cheers Graham. O0
polobeer
« Reply #15 on: August 28, 2007, 08:34:11 am »
Good to hear from you Graham. I've continued to sort the boat out over the weekend; another coat of green paint; applying weather-proof PVA glue to the inside of the hull then gloss yacht varnish, and re-fixing some of the fittings. It's beginning to take shape. Photos soon.
All the best
Simon  :D
janjac
« Reply #16 on: August 28, 2007, 10:51:31 pm »
Hi all
I have read the entries on St.Canute, and will enclose a picture from the 50`s showing St.Canute/Sct.Knud with damage to the rudder being towed by 2 small boats!!
jan
polobeer
« Reply #17 on: August 29, 2007, 11:33:28 am »
Dear jan,
Your photos of Sct.Knud are really excellent! Keep them coming because they are very inspiring!
With best wishes,
Simon  O0 O0
Archibald H.
« Reply #18 on: September 06, 2007, 04:13:07 pm »
Hi Simon,
I've finished mine about a month ago:
You can see more pics of the build here:
http://www.modelbouwforum.nl/phpBB2/viewtopic.php?t=53816
This is an interesting link about the real thing (now called S/S Stockvik).
http://www.tugboatlars.se/Stockvik.htm
And apparently she's back under steam, very impressive:
http://s178.photobucket.com/albums/w244/Ackebooa_stockvik/?action=view&current=Stockvikteaser.flv
Some changes I did was making a new cardboard funnel in stead of the plastic one provided and new plastic vents in stead of the brass ones to make her less top heavy. This improved the stability a lot. I replaced the steps on the sides of the superstructure with ladders for easier acces to the inside.
As you can see I renamed her 'Vilcabamba' and have no use for the decals that were included in the kit. If you're interested you can have them. Just let me know.
Lots of succes with the restauration.
Regards, A!H
Captain Povey
« Reply #19 on: September 06, 2007, 04:50:10 pm »
Hi A!H, That looks like a very impressive build. Interesting that you also had problems understanding the construction of the towing hook as I did also and I am not sure I got it right. You have a very good point in replacing the funnel with a less heavy one. I wish I had thought of that. Cheers Graham. O0
polobeer
« Reply #20 on: September 06, 2007, 06:18:06 pm »
Dear Archibald H,
Many thanks for your posting and the offer of the decals. I think I'll be alright in this respect, but it was a very generous offer. Your model of "Vilcambamba" looks very nice indeed and the funnel made from card is an interesting idea. Your photos are also excellent (plus the links). I will post some more photos of my rebuild soon so watch this space!
Kind regards and thanks again  :D :D
Archibald H.
« Reply #21 on: September 06, 2007, 11:44:11 pm »
Hey Simon,
no problem, if you change your mind: there not going anywhere for the moment  ;)
@Captain Povey
Yes Graham, that towing hook was a bit of a mysterie. Luckily there are forums, one of the best things on the internet.
I had problems with the stern too. I used balsa blocs to make a form I was satisfied with. I found it impossible to accomplish that with planks . . .
All in all it turned out okay. Still waiting for better weather for it's maiden trip.
Cheers, A!H
Archibald H.
« Reply #22 on: September 08, 2007, 07:43:42 pm »
Hi all,
today I found the time and the right weather. I was surprised about the stability. Very manoeuvrable too, for a rudder of such a small size.
After half an hour the fuse blew :o. Perhaps it had something to do with the speed controller, it happened when I changed rather quick from forward to reverse. Maybe the fuse was rated to low . . .
All in all I'm quite satisfied.
Regards, A!H.
Captain Povey
« Reply #23 on: September 08, 2007, 08:46:42 pm »
Hi A!H, Very nice pictures there. She looks really good. Shame about the fuse. Perhaps the prop got caught in some weed which momentarily caused an overload? I notice that your model has the front spar fitted. Is that your addition or part of the kit as I did not see it on my plans but have seen it on some other models. The video clip on the Stokvik site is very interesting and I had assumed it had been taken during the journey from England to its present rebuild dock. Cheers Graham. :)
janjac
« Reply #24 on: September 08, 2007, 09:16:03 pm »
Hi Archibald
Very nice looking model you have there, hope you solve the fuse problem ?
Hi  Graham, the derrick was removed shortly after St.Canute started for Fowey HS along with the fenders, even for some time the lifeboats was removed from the ship, I enclose a photo from Fowey showing St.Canute without the items I just mentioned.
Jan
Page created in 0.221 seconds with 17 queries.
