Author Topic: paddle boats keels?  (Read 2326 times)
newbe7
paddle boats keels?
« on: December 15, 2015, 01:35:44 pm »
I received the plans for the paddle wheel boat Maid of the Loch looking at the views I don't see a keel showing do paddle boats have keels if so is the keel internal  or flush with the hull.
Rick
Re: paddle boats keels?
« Reply #1 on: December 15, 2015, 04:45:25 pm »
Very few full size vessels have external keels, usually they are built into the double bottom structure. The bottom of the hull is flat. However potentially unstable models such as paddle steamers may have fixed or detachable sailing keels to improve their stability.
One option if you are uncertain is to build in a couple of fixing points to the bottom of the hull such as brass threaded sockets which can be used to accept a sailing keel, or indeed a variety if you are experimenting! They can be removed when the model is on display or in storage.
