Author Topic: brushless set up single prop  (Read 2257 times)
MadMax
« on: December 17, 2015, 04:53:25 pm »
hi all where to fit fuse on brushless set up
                       can anybody help
sparkey
Re: brushless set up single prop
« Reply #1 on: December 17, 2015, 05:15:49 pm »
Between battery and ESC as you would on a brushed set up,+ or - does not matter which pole,I use car type flat blade fuses and measure current of motor under load then fuse just above that,used this method on my boats and never had any trouble.....Ray.
MadMax
« Reply #2 on: December 17, 2015, 05:59:12 pm »
hi ray
         thanks for reply .....thats the way i would do it with brushed motors but brushless have three wires from the motor
         dos it matter where the fuse gos
« Reply #3 on: December 17, 2015, 06:20:59 pm »
Don't put one between the motor and ESC
If you must use a fuse then between the ESC and the Battery
sparkey
« Reply #4 on: December 17, 2015, 06:22:31 pm »
Always between the battery and ESC NEVER between ESC and motor or the ESC is not protected so ignore the 3 wires as it does not apply...Ray.
Page created in 0.557 seconds with 21 queries.
