Author Topic: identifying paint  (Read 3141 times)
cos918
identifying paint
« on: December 22, 2015, 10:15:19 pm »
Hi All
I am restoring some second hand models. The problem is I dont know what type of paint has been used. So when I come to repaint the models I want to avoid any paint reaction . Is there any way to identify what paint has been used ?
john
cos918
Re: identifying paint
« Reply #1 on: January 06, 2016, 08:36:06 pm »
any got an ideas apart from taking pot luck ?
john
« Reply #2 on: January 06, 2016, 08:39:01 pm »
I can't help on paint identification but can recommend this stuff:-
http://www.ebay.co.uk/itm/HB-Body-Pro-Isolator-Spray-Paint-400ml-5200000003-/281809889811
Simply flat down the old paint, spray a layer of this followed by a coat of primer then paint with your chosen paints
« Reply #3 on: January 06, 2016, 09:18:08 pm »
get some cellulose thinners or similar and try a bit that is hidden....if it wrinkles up then the chance is that it is enamel....Keep the wet rag on it for a bit ......if the paint simply comes off then there is a darned good chance that it is a rattle can
« Reply #4 on: January 06, 2016, 09:51:28 pm »
I would still suggest a coat of isolator afterwards, just as belt and braces
cos918
« Reply #5 on: January 07, 2016, 04:35:06 pm »
Hello all
Thank you for the tips . I will look in to both
Page created in 0.012 seconds with 21 queries.
