Author Topic: Pegasus - Ventouris Ferries  (Read 3068 times)
dana futura
« on: January 03, 2016, 09:47:33 am »
The last months I am running a new project. The ship is the ex. Espresso Venezia in her greek version.
I change a little bit the materials from Venus, using now 4mm plywood for the frames, and 2mm Balsa strips.
After finishing the surface I will apply one fiberglass 80r/m2. I hope it will be ok.
Here are some frames and the deck parts
Dinos
dana futura
Re: Pegasus - Ventouris Ferries
« Reply #1 on: January 03, 2016, 09:49:39 am »
Finishing all the side parts, bow and stern, apply some soft putty and then sanding, sanding, sanding..
Dinos
dana futura
« Reply #2 on: January 03, 2016, 09:51:10 am »
The hull as is now, waiting for the fiberglass application.
Dinos
Brian60
« Reply #3 on: January 03, 2016, 10:29:06 am »
This is looking good so far, I think you have the makings of a superb ship.
BFSMP
« Reply #4 on: January 03, 2016, 11:20:50 am »
What a beautiful shape this hull has.
This will be a lovely looking model I am sure.
Jim
dana futura
« Reply #5 on: January 03, 2016, 01:36:24 pm »
It is not a very easy hull. Lot of angles and curves. I hope she will look like the real one at the end
Dinos
boathound
« Reply #6 on: January 03, 2016, 03:47:01 pm »
Wow, how did you make the bulb for the bow, is it all soft putty?
dana futura
« Reply #7 on: January 03, 2016, 04:00:57 pm »
No it is complete from balsa. I cut some frames from plywood for lines reference, then fill the gaps with balsa and sanding until it looks ok. Off course it needs some "fine sanding" but not at this stage.
Dinos
cos918
« Reply #8 on: January 03, 2016, 06:16:45 pm »
Hello
Nice to see you are building a new ferry . You project is looking good.
« Reply #9 on: January 03, 2016, 06:23:18 pm »
Did the balsa bend and form easily to the frames or did you soak the strips first?
Excellent build so far!
« Reply #10 on: January 03, 2016, 10:20:52 pm »
Can't have too many ferries I say. Must be nice to have your warm weather to sail in.
dana futura
« Reply #11 on: January 03, 2016, 10:24:16 pm »
Yes very easily. It is only 2mm sheet. I cut some strips for the difficult parts.
Dinos
dana futura
« Reply #12 on: January 21, 2016, 09:40:29 pm »
Next steps
Hand over the hull to my good friend who is epoxy expert. After applying 80gr fiberglass he start covering the hull with fine epoxy putty.
Below some progress
Dinos
markrider
« Reply #13 on: January 24, 2016, 10:47:48 pm »
great build , love a ferry
Page created in 0.087 seconds with 21 queries.
