Author Topic: Checking sizing on 1/12 Severn.  (Read 2482 times)
lesfac
  • Never too late for a happy childhood
« on: January 03, 2016, 02:49:31 pm »
Could anyone tell me quickly what are the dimensions on a 1/12 Severn rudder.
Working from drawings I have access to I thought the following would apply
Vertical height 62mm (ish)
Top edge 58MM
bottom edge 26mm
The rudder i have measures
Vertical Height 50mm
Top edge 50mm
bottom edge 22mm
There could be a few reasons for this including I am getting it wrong or the drawings have been updated.
Thanks in advance
Les
  • Do it nice or do it twice !
Re: Checking sizing on 1/12 Severn.
« Reply #1 on: January 03, 2016, 05:01:18 pm »
Hi Les,
 My rudders are 63mm deep, 60mm across the top and 26mm at the lower edge, at 12th scale.
The RNLI drawing measures out at 63mm X 64mm x 26.5mm, however the docking plan shows it to be 62 x 57 x 25mm.
a small discrepancy in the plans, If I had known I could have measured them accurately when the boat was out for hull cleaning.
 Kind regards  17-09
lesfac
« Reply #2 on: January 03, 2016, 08:19:03 pm »
Thanks for the quick response.
I was double checking the plan to see where to drill the rudders when I became aware that the rudders in the kit are a different size to what I was deducing from the drawings.
I don't know if there is a logical explanation for this
Les
« Reply #3 on: January 04, 2016, 09:30:04 am »
Les,
 Cannot answer that one, rudder size can increase the effectiveness in model form sometimes!
lesfac
« Reply #4 on: January 04, 2016, 09:41:21 am »
Hi 17-09
Thanks for your speedy response.
Out of interest where does your 1/12 Severn come from? Was it a kit?
Les
« Reply #5 on: January 04, 2016, 02:45:19 pm »
Hi Les,
 Yes it's a Speedline, ex Phil Locke,s, now rebuilding as Dover's boat. Took it back to a kit again then spent three years making many new parts from information and research on the real 17-09. quicker to start from scratch I fear, another year at least required.
good luck with yours
17-09
