Author Topic: Electronic circuit diagram imaging software  (Read 2899 times)
C-3PO
« on: January 12, 2016, 11:48:33 am »
Can anyone point me in the right direction for an easy to use circuit diagram application.
Want to be able to make (draw) simple images/diagrams. Something like Mr ActionElectronics used would be great. Inertia can you help?
Thank you in advance
C-3PO
The Old Fart
Re: Electronic circuit diagram imaging software
« Reply #1 on: January 12, 2016, 01:24:38 pm »
If its circuit board designs, then go for RS components Design Spark.
Free program.
HMS Invisible
  • MICROGYROS.COM
    • Yes, it works!
« Reply #2 on: January 12, 2016, 02:44:07 pm »
Try the Expresspcb schematic editor.  http://www.expresspcb.com/expresssch
It has been a while since I used it but I do recall cropping and converting the .bmp files to smaller .gif files using mspaint.
inertia
« Reply #3 on: January 12, 2016, 03:14:51 pm »
The wiring diagrams I draw aren't electronic or PCB circuit diagrams at all - they're more like pictures. I use an ancient (2003) copy of Corel Graphics Suite which has CorelDraw12 (Ver 12.0.0.458 to be exact)  as a part of it. The current market version is CorelDraw X7* but there are freebie programs available which I'm sure will do the same job. My old mate Pete Kierle used to do a very similar job using Windows Paint.
The good thing about a vector graphics program is that you can import JPG's and also CAD formats like DWG and DXF, and export your finished file as JPG or PDF; all very useful formats.
Dave M
*Home and Student Version is about £85 from Curry's.
Brian60
« Reply #4 on: January 12, 2016, 03:45:23 pm »
This is the one and only page you will ever need when it comes to designing circuits. Every icon  for electronic/electrical/electro-mechanical is available...........
http://www.digikey.com/schemeit/#2ek9
« Reply #5 on: January 12, 2016, 04:11:44 pm »
Depends a bit on what you want to draw.
A drawing showing module to module connections (lines joining boxes), with care and attention, can be done with most basic drawing programs like Paint, or MS Publisher or the others mentioned.
A circuit drawing at component level would probably need something with the right symbols built in. Diagram Designer works, http://www.freewarefiles.com/Diagram-Designer_program_8116.html Free, so only learning time as an investment.
C-3PO
« Reply #6 on: January 18, 2016, 12:20:11 am »
Thank you for all the suggestions - sorry for the delay.
It's taken some time to work through them all - I have found Fritzing does what I want.
http://fritzing.org/home/
C-3PO
Page created in 0.514 seconds with 17 queries.
