Hi Les
Start with an accurate vertical centreline, mark this with a line of tape, all the measurements to the centres of the exhausts, trim tab guide plates and other fittings can be marked off horizontally from this mark, the measurements in mm’s are simply divided by 12 to give the model sizes, i.e. the 850mm distance from centreline to centre of exhaust is 70.8mm and therefore the exhausts are 141.6mm apart. The vertical height is trickier, you will need to accurately set the boat up on a flat surface and make a baseline which is 11.6mm higher than the lowest part of the keel, the drawings show this clearly, 140 divided by 12 will give you 11.6mm. The vertical measurements can be marked off again by using tape. It is now some time since I done this work but do remember it gave me some headaches, if I recall the hull size did not work out to be totally accurate and some minor adjustments need making. I also had the advantage of being able to view the real boat and take certain measurements myself, not always possible as the boat is obviously afloat. The waterline changed on the Dover Severn, I believe due to new engines adding to the weight, I was able to mark the new waterlines accurately and most of the transom fittings worked out correctly when viewed from astern, the old adage, “If it looks right it probably is” was applied. If it helps, the distance from the top curve of the transom to the top of the waterline is 139mm, vertically, 140mm actual. The exhaust centres are 40mm up from the top of the waterline, the waterline is 6mm thick aft. Remember the rake of the transom and to some extent the curve on the plan view will alter the measurements slightly, the plan being flat. All this is of course from the Dover Severn boat, others may be different
Regards 17-09
