Author Topic: Need Gasket for my Robbe Sea Wolf V2  (Read 6458 times)
Re: Need Gasket for my Robbe Sea Wolf V2
« Reply #25 on: February 12, 2016, 09:22:36 am »
My seawolf project is on hold at the moment so if it helps I can send you my WTC so you can better see how the bayonet works
David_l_perry
« Reply #26 on: February 12, 2016, 09:33:53 am »
I may take you up on that offer !  This is on my 'want to do list', rather than 'must do straight away' list.  :-)
If I don't get any joy from the suppliers that I have emailed, then I will start looking at getting one made up.  Ideally I will find somebody at the local club in my area (North West) with a sub that I can look at , but if not that may be of real help.  In the meantime that original O ring would be ideal so at least I can sail it as its all up and running
Thanks for all the help so far !
« Reply #27 on: February 12, 2016, 10:18:02 am »
Ok I'll get the O-rings in the post this weekend.  I still have your email address
David_l_perry
« Reply #28 on: February 12, 2016, 10:21:44 am »
Spot on thanks.  :-))
Subculture
    • Dive-in to Model submarines
« Reply #29 on: February 12, 2016, 11:43:27 am »
Have you got a lathe, or know someone with one? If so you could machine a radial end cap up. I wouldn't copy the German design, as it's quite a lot of work,, you could just have a machined ring with a radial seal, but use the original threaded retainer to keep the two halves of the boat together.
David_l_perry
« Reply #30 on: February 12, 2016, 11:50:47 am »
As it happens Norbert Bruggen has just emailed back and will make one for me.   :-))
I would still like the o ring sent over please as its likely to take a while before he gets this made, and possibly longer before I get round to installing it.....
« Reply #31 on: February 12, 2016, 12:40:34 pm »
No worries :)
Ill sort them out at the weekend
