Author Topic: House latex for filler  (Read 4608 times)
Hande
  • Dream being fulfilled after 47 years.
« on: January 31, 2016, 09:32:04 am »
Did I mess up?
True to my signature and based on a tip, I tried house latex for filler on my ABS hull. Tamiya putty seemed too expensive and thick. I tried thinning the putty with hardware store lacquer thinner (white spirit) (I know, there's a Tamiya LT product, but costly), but the putty behaved weird - it went in to an awkward clumpy porridge.
The latex was easy to spread with a sponge-brush and with enough of elbow grease it was fairly easy to sand. It sticks well.
How does it work with Vallejo Model Color? I'm planning to apply a plastic primer before the Vallejo paint.
Trial-and-error doesn't spell failure - right?
Re: House latex for filler
« Reply #1 on: January 31, 2016, 12:30:11 pm »
I am puzzled by what house latex is.
Could you provide a little more info please.
Hande
« Reply #2 on: January 31, 2016, 01:10:54 pm »
I was not sure about the English.
In Finland we typically use certain water-based paints ("latex") for e.g. walls of rooms indoors.
Hence "house latex".
I have read that the base substance of latex paints has something to do with rubber.
There is no rubbery feeling in the end result, though[size=78%].[/size]
« Reply #3 on: January 31, 2016, 01:52:56 pm »
Hande
Can you post up a pic of the packaging and maybe I can do a better translation :)
I would suggest a coat of isolator spray before doing any painting just to be certain
Something like U-Pol 720 (Hopefully you can find a cheaper one in Finland as the U-Pol stuff is very expensive over there)
Big Ada
« Reply #4 on: January 31, 2016, 06:04:11 pm »
Household Emulsion Paint ?
« Reply #5 on: January 31, 2016, 06:08:09 pm »
Americans call 'Emulsion' paint 'Latex' paint, so perhaps the Finns call it that as well?  Being waterbased, I would have thought it needs a water based thinner, or maybe even just water to thin it.
Plastic - RIP
  • Inactive
  • Bobbing Along!
« Reply #6 on: February 01, 2016, 06:54:25 am »
I think he might be talking about 'painter's mate' - the acrylic gap-filler stuff in a tube used for decorating.
Hande
« Reply #7 on: February 01, 2016, 11:48:09 am »
Sorry folks. I was hospitalised for a little stretch...
It's a proper paint - not a filler. Comes in paint cans that only come with Finnish and Swedish text.
Dispersion paint - thinned with water. Indoors. Not really meant for plastics.
Reaches final cure in 4 weeks (!). This means that it's chemical properties against solvents etc. are reached 4 weeks.
It seems just perfect in terms of handling. I will follow essex2visuvesi's suggestion to use an isolation spray (primer). Would a paint primer not do? See the latter two pics.
By googling "Tikkurila REMONTTIMAALI 20", you can find the data sheet. (Good for you e2v if you read Finnish!)
Hande
« Reply #8 on: February 01, 2016, 11:59:13 am »
For the insulator, would a painting primer not do?
Hande
« Reply #9 on: February 01, 2016, 12:03:29 pm »
About my MOTIP plastic primer.
Is there a chance that Vallejo acrylics don't stick well to it?
I have made a test: by sanding, the paint came off very easy, but I thought I was being too rough and used too small-numbered a grit.
« Reply #10 on: February 01, 2016, 09:26:52 pm »
How long had the vellejo been left todry before sanding? I ask because my experience ith vellejo is that it has a flexible vinyl phase before fully curing when it can be a bit fragile.
Hande
« Reply #11 on: February 02, 2016, 10:51:04 am »
I let it cure for 2-3 days after the 3rd coat. I hadn't used varnish, yet, when I decided to fix some flaws on the surface. My mistake really was that I didn't let it wait long enough between coats. I think that's it...
Page created in 0.016 seconds with 22 queries.
