Author Topic: Acrylic over enamel?  (Read 3652 times)
Norman Castle
« on: February 01, 2016, 01:41:58 pm »
Sorry chaps - me again  :embarrassed:
I have a ply hull which has been brush-painted with Humbrol enamels.  Can I safely over-coat it with Tamiya acrylic after a light rubbing down?
A positive attitude may not solve all your problems, but with any luck it will annoy enough people to make the effort worthwhile.
Re: Acrylic over enamel?
« Reply #1 on: February 01, 2016, 02:21:38 pm »
Quite simply No
I had exactly the same issue with my Tirpitz
You need to rub it back as best you can then coat with an isolator primer or you may get reactions
This is the stuff I used on my tirpitz
I'm sure there will be people who say it'll be fine, and it may well be. BUT do you want to take the chance?
Norman Castle
« Reply #2 on: February 01, 2016, 02:41:26 pm »
Oh poo! I've got three coats of Humbrol enamel on all dried and rubbed down, and last night I started on the camouflage-style top coats for which I wanted to use six colours.  I now find that three of the new tins are dud, which on top of other paint problems has finally finished me with Humbrol  >>:-(
I really don't fancy rubbing right back to the bare wood and I don't fancy paying over a tenner for isolator primer when I can't really use rattle cans, so I'll reluctantly go for a revised colour scheme using Humbrol tins which I know are OK.
Once this build's finished, I ditch my remaining tins of Humbrol and go 100% Tamiya acrylic for sure ...
Arrow5
« Reply #3 on: February 01, 2016, 03:41:20 pm »
Do you HAVE to use spray cans ?   Expensive.
..well can you land on this?
TailUK
« Reply #4 on: February 01, 2016, 04:57:34 pm »
There shouldn't be a problem using water/alchohol based acrylics over enamel provided the enamel is suitable "cured" (left long enough to dry!)  The problem could arise if your using aerosols.  I personally wouldn't use car paint over enamels but brushed on or air brushed hobby acrylics should be ok.  A problem you might find is getting the coverage over the base colour.
Norman Castle
« Reply #5 on: February 01, 2016, 05:35:55 pm »
Eh???????  I don't use spray cans  :-)
« Reply #6 on: February 01, 2016, 08:34:39 pm »
Simply JUST DONT DO IT as it will end in TEARS
Arrow5
« Reply #7 on: February 01, 2016, 09:00:13 pm »
   My mistake , sorry. :embarrassed:
Page created in 0.013 seconds with 21 queries.
