December 09, 2025, 06:58:21 pm
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
Register
Technical, Techniques, Hints, and Tips
Radio Equipment
Servo prob.
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: Servo prob. (Read 2916 times)
Ginger64
Full Mayhemer
Offline
Model Boat Mayhem is Great!
Bucks
Servo prob.
on:
March 11, 2016, 09:15:33 pm »
Just up graded my boat from 6v to 7.2v. Now I have a servo inside boat which has stopped working. Is it possible the 7.2 volt battery is too high for the servo and blown it.
radiojoe
Full Mayhemer
Offline
Gosport , Hampshire , England
Re: Servo prob.
Reply #1 on:
March 11, 2016, 09:51:07 pm »
It would depend on the where the Rx power supply comes from, it should be either be a 5volt BEC from the ESC or a separate Rx battery up to 6volt, so the servo should never get 7.2 volt.
Ginger64
Full Mayhemer
Offline
Bucks
Re: Servo prob.
Reply #2 on:
March 11, 2016, 10:07:11 pm »
Servo is plugged in receiver. But like I said it has now a 7.2 battery to it via esc. Just might be coincidence that it's stopped working. Is it possible to wire it direct to a battery to test if it works. This would rule out receiver problem. If it has one.
radiojoe
Full Mayhemer
Offline
Re: Servo prob.
Reply #3 on:
March 11, 2016, 10:16:05 pm »
The lead from the ESC is the BEC and is only 5 volts regardless of the voltage of the main battery, it sounds like a faulty servo.
Ginger64
Full Mayhemer
Offline
Bucks
Re: Servo prob.
Reply #4 on:
March 11, 2016, 10:35:55 pm »
Thanks very much for your help radio joe .
Full Mayhemer
Offline
Blackpool, Lancs, UK
Re: Servo prob.
Reply #5 on:
March 12, 2016, 10:30:06 am »
Apart from fitting it into a known working installation, the only way to test a servo is to plug it into a servo tester. About 2 quid from fleabay. Powering it just applies power, to check its working it needs a pulsed signal on the third wire.
Print
Pages: [
1
Go Up
« previous
next »
Radio Equipment
Servo prob.
