Author Topic: brushless help-again, with thanks  (Read 2935 times)
bill stafford
« on: March 29, 2016, 08:00:19 pm »
dear forum members,
i was looking for a small brushless, for a warship type hull, currently twin shafts ,maybe go to single shaft ??approx. 760mm+90mm
what is available to turn a 40/45mm prop ??
am I correct in saying approx. turn a prop 25% larger in diam. than the motor ??
which would be a 30/35mm brushless will turn a 40/45mm prop ?
thinking also of using li-po battery to drive model , which will be 12 months away.
thanks for your help and opinions
bill stafford
bill stafford
Re: brushless help-again, with thanks
« Reply #1 on: April 04, 2016, 12:27:55 am »
seems this is too hard , or not enough info for a answer.
I will try  a skm 3 35/45 mm brushless,the 1000kv version is a lower wattage than the 840 kv version, in theory
thanks bill stafford
canabus
« Reply #2 on: April 04, 2016, 06:45:20 am »
Hi Bill
A few motors to look at are the Hobbyking 3639-750kv, 3648-600, 4250-580 and 4248-400kv.
Brian60
« Reply #3 on: April 04, 2016, 07:07:00 am »
Bill you are looking for help powering a warship type hull with brushless power. This is the tug section.
You would be better off asking it in the warship section or even the technical brushless section.
