Author Topic: help needed to i.d a action unit  (Read 709 times)
ray123
  • mary marie cygnus gm33
« on: May 11, 2016, 12:15:35 PM »
hi all i was givern this action unit   on the circuit board it has  P33    i have no paper work with it  to say what it is   im thinking its a speed control
so if anyone knows  or has a diagram of it  & could let me know that would be a great help thanks
inertia
Re: help needed to i.d a action unit
« Reply #1 on: May 11, 2016, 12:55:59 PM »
It's a Slim 15A speed controller circa 1995; 2v - 12v motor supply. Wiring on the terminals block (from top down to bottom) is Motor, Motor, Positive, Negative (same as P80 is now). The tabs on the two MOSFETs can get hot; I'd advise removing that corner of the case lid to provide cooling. I think the two pots adjust the neutral and peak motor speed values.
What's the betting that Stan Reffin has a copy of the instructions?   8)
Dave M
ray123
« Reply #2 on: May 11, 2016, 02:09:38 PM »
thank you  dave thats a great help  :-))  all the best regards ray
