Author Topic: 1/20 Severn Class  (Read 9951 times)
ferny
Re: 1/20 Severn Class
« Reply #25 on: January 29, 2020, 06:19:47 pm »
Thanks, I am chuffed with how she turned out !
Aidank
« Reply #26 on: March 24, 2020, 10:37:13 pm »
Motors and steering gear all done. Quick test in the bath and all worked as it should.
this looks fantastic! would love to know the spec of the Hardware your using? i have a very upset Son who's identical lifeboat has stopped working for some unknown reason! all the research seems to be brush less motors/esc's etc but it all seems too big for this hull? would love a source of knowledge of how best to kit out replacement parts
ferny
« Reply #27 on: March 25, 2020, 08:18:33 am »
Thanks!
Here a list of what I used :
2 x MABUCHI RK-370SD-5028 DC 3.7V-11.1V motors
2 x motor mounts
2x radioactive 300mm propshafts (will need cutting down)
Rubber prop coupling
20mm LH prop
Mtroniks 10 amp viper ESC
1 micro servo
1.6mm brass wire for steering linkages
2 small approx 15mm rudders
You will also need to replace the stock transmitter and reciver to many options to list !
And it's all powered by 1000mah 2s lipo.
All available from ebay and most well stocked hobby shops
« Reply #28 on: March 25, 2020, 08:28:35 am »
Also, go back to the front page of thr Forum and do a search for baby severn
Aidank
« Reply #29 on: May 08, 2020, 02:39:04 pm »
2 x motor mounts
20mm LH prop
1 micro servo
this looks fantastic! how does she perform? have you had her in the water yet?
Aidank
« Reply #30 on: May 08, 2020, 04:11:04 pm »
any links would be great! keep finding props that dont suit shafts or shafts then no props! assume you used an m4 prop shaft? ive found 2mm but then cant find props, all m4 props seem too big?
Aidank
« Reply #32 on: May 09, 2020, 06:21:27 am »
https://www.amazon.co.uk/gp/product/B07MLFMZ7F/ref=ox_sc_act_title_1?smid=A38WCF64ZZVDKC&psc=1
found these which might be easier still! available in 250mm or 300mm so may try the 250mm
Aidank
« Reply #33 on: May 10, 2020, 04:25:01 pm »
Assume even though you used two ESC's they were both powered from a single battery or do they need one each? newby apologies!
ferny
« Reply #34 on: May 10, 2020, 05:09:33 pm »
Only used the 1 esc to keep the weight down.
Aidank
« Reply #35 on: May 12, 2020, 04:03:00 pm »
Ah ok! i see your motors are wired together now! id love full function on both but you may have the right idea with saving weight!
Page created in 0.11 seconds with 21 queries.
