Author Topic: Difference between Props.  (Read 2994 times)
Glyn Roberts
  • Creativity is contagious, pass it on.
« on: June 07, 2016, 05:15:02 pm »
What is the difference between 2 blade SR type high speed GFN Propelers   &   2 blade X type high speed GFN Propelers.
How does the difference affect a boat.    Need to know this before ordering the Props.
Thanks and regards Glyn
Subculture
    • Dive-in to Model submarines
Re: Difference between Props.
« Reply #1 on: June 07, 2016, 05:36:48 pm »
Pitch is coarser on the x type. Should give more thrust, but will also create a higher torque moment, e.g. twist the boat over more if its single screw, and will also load the motor up more.
roycv
« Reply #2 on: June 07, 2016, 05:44:18 pm »
Hi, I seem to remember that the finer pitch props have a 1.4 X prop diameter pitch and the coarse ones 1.7 X diameter of prop. Stand to be corrected though.
regards Roy
Subculture
« Reply #3 on: June 07, 2016, 05:58:48 pm »
1.2 and 1.4x prop diameter usually. 1.7 would be very coarse, sort of thing reserved for steam driven boats or heading towards surface piercing prop pitch.
inertia
« Reply #4 on: June 07, 2016, 06:45:59 pm »
SR = better acceleration, lower top speed, less torque reaction, less current draw
X = the opposite of all of those, all other things being equal
DM
roycv
« Reply #5 on: June 07, 2016, 11:28:24 pm »
Hi I use the small diametder coarse pitched props for my motorized sailing yachts as when stationary they cause less drag.
regards Roy
Glyn Roberts
« Reply #6 on: June 08, 2016, 05:44:31 pm »
Thanks for all reply's,  good job I asked rather than sailing on in ignorance as the information turned out to be critical.
Regards and thanks Glyn
