Author Topic: Radiolink receiver R9D  (Read 3382 times)
chumphon
« on: June 13, 2016, 04:24:32 pm »
A quick question
On the radio link receiver there is a rubber fuse type thing on the antenna its a pain because i want to feed whole antenna wire through a small hole in the hull,,, can i remove iti am using it in a carbon fibre hull so with my other receiver (s) i just fed the whole antenna through the port where steering line goes
is this rubber thing standard on all their receivers?
and no i dont want to drill a bigger hole in the hull
The AT9 package is ok (apart from transmitter screen which is impossible to read in bright sunlight)well it s cheap in thailand it has far more channels than i would ever need i do not use any telemetry but sail in ocean so strong signal is paramount
any advice would be welcome
inertia
Re: Radiolink receiver R9D
« Reply #1 on: June 13, 2016, 04:32:32 pm »
Chumphon
A quick answer (well, two answers actually):
No, it's not a fuse and no, you can't remove it without seriously compromising the range. Sorry if that's not what you wanted to hear.
DM
« Reply #2 on: June 13, 2016, 06:23:44 pm »
The only part that needs to be outside the hull is the shiny 1" at the end because that is the aerial.  The rest is a shielded coax feed for it.  The length of both is quite critical for performance.
chumphon
« Reply #3 on: June 14, 2016, 02:06:23 am »
Thank you both
unfortunately due to this rubber thing  i can only get about a quarter of an inch of the aerial (if that)outside the boat Grrrr
signal seems ok but it does twitch occasionally whereas my other receivers i never had a problem with
inertia
« Reply #4 on: June 14, 2016, 08:53:05 am »
I think you'll need to re-site the receiver. The manual for the Rx says that the aerial should be kept at least 1/2" (12mm) away from any metal or carbon-fibre skin etc.
DM
« Reply #5 on: June 14, 2016, 10:04:33 am »
As unhappy as you are about increasing the hole size, doing that and using a grommet is the "proper" approved way of getting a wire through a panel.  It serves to both seal against water getting in that way and to protect the wire against chafing on the edges of the hole.  I have a tendency to use a clear waterproof adhesive like UHU All-purpose to do the job.
In all probability, the "rubber fuse" is likely to be the outer sleeve of the coax folded back over itself to provide a firm watertight or vibration resistant seal in the right size hole.
chumphon
« Reply #6 on: June 14, 2016, 10:26:56 am »
Thanks again guys re siting is not an option as whole hull is carbon fibre its a stockmaritime 3x1 hull
i might sail until the really  windy season with this and in the meantime try to locate another transmitter that i had before (storm I6s) its made by the OEM of the orange T6 and its receiver has 2 long wires i just feed through the steering lines.
its a shame i had phenomenal range before! just the transmitter got old and corroded (i stand in the sea off a beach its 35 degrees plus each day so sweat and sea water don't help)so no transmitter lasts more than a few years.
i never checked that the antenna was different with this receiver so its my fault
Also the receiver is situated right between the servos on top of the battery so i suppose it gets a fair bit of interference although it never seemed to bother the cheap charlie system before
At the moment (today) i only get a bit of problems when the boat is healing away from me at a distance of i suppose 100 metres so its not a massive issue until we start getting the big waves and swell which i sure will interfere more.
