Hi from a very wet Downunder.
I buy quite a bit of mainly model stuff from China, both Ebay and direct from a major seller who has warehouses in a couple of other countries. I rarely buy from Hobbyking, as has been mentioned previously, the postage cost makes it less attractive.
Generally the stuff averages around 3 weeks to get here, but if you factor that in, it's not so bad. Some stuff from the other seller gets here in under 2 weeks and it then has a name and address of a Sydney freight distribution network on it. Maybe it's bulk freighted to Aus, then it goes in the post. It's in the usual grey plastic bag, sometimes with too little packing, but normally arrives in good condition. I don't care where it comes from as long as it gets here in good condition, and it nearly always does. Being in the bush and a long way from any hobby shop, Ebay is a great place to get the stuff you need. My nearest Hobby Shop is 65kms away, and they almost never have what I need, so the next option is 350kms+ which I don't do very often!
I just had to replace a Robbe ESC which developed a dead short and was melting fuse holders before blowing a fuse, but wasn't prepared to go Robbe again due to the cost. I chose to buy a selection of cheap Chinese Brushed ESC's at around AU$11.00 to AU$22.00 ( posted ) at the usual 320amp? rating. As I probably only pull well less than 20 amps in most models, there is ample safey margin! These vary slightly in performance in the F/Brake/R function, and I'm still looking for one with no real brake. The best so far has been a unit from Hong Kong rated at 110amp forward and I think 60amp reverse, and this cost AU$26.90 posted. It does everything the Robbe did and transtions quite smoothly from F to R. I know there is a quality difference between European and Chinese, but now on a limited income, price is more important. I had used one of these previously which I had bought from a local Ebay Seller for almost the exact same money plus postage, but he no longer lists them, so buying from overseas for the same sort of money posted, makes sense.
Long live Ebay and PayPal!
Ian.
