Author Topic: Using the TX switches for motor  (Read 1021 times)
PhilandIom
« on: August 02, 2016, 09:13:52 PM »
I am building a sailing lugger fishing boat (Louis Heloise). I would like to use the TX on/off channel switch to run the motor as a self rescue. What is the minimum electronics I need and how do I wire it, I don't need speed control just a simple on/off control to get the boat back when the wind dies mid lake. I am thinking of using a separate battery to power it.
Re: Using the TX switches for motor
« Reply #1 on: August 03, 2016, 12:43:01 PM »
Cheapest is a servo with a switch attached.  The TX switch alters the state of its channel, the servo moves, operates the switch.
Next up is a switcher, basically a set of servo electronics that operates a relay or equivalent.
KevinM
« Reply #2 on: August 03, 2016, 04:05:56 PM »
For me a pure electronic solution switching a motor seems easiest and cheepest
« Reply #3 on: August 03, 2016, 04:44:20 PM »
Turnigy electronic switches are only a couple of quid and no need
to make up a servo/switch board.
Easier and can be positioned just about anywhere.
PhilandIom
« Reply #4 on: August 03, 2016, 05:16:04 PM »
Thank you chaps, I thought it must be possible but I was looking i the wrong places and with the wrong search terms for the answer. Newby basic error. :-))
« Reply #5 on: August 03, 2016, 05:43:29 PM »
I think my cheap electronic switcher would not like the startup
current of a motor and would need to have a relay to switch
the motor supply as Malcolm has said.
Sorry for posting before thinking <:(
steamboat66
  • maybe it will float!
« Reply #6 on: August 03, 2016, 06:20:12 PM »
pololu solid state switches. they plug into the RX and have a low side driver, (they switch the negative side). active robots is one source, and uk.
