Mounting the bow rudder frame permanently today:
Double and triple-check the locations of the parts of the rudder frame that locate in the hull, mark with a pencil and then cut and drill as necessary. Then to locate the exact spot to drill for the rudder post, insert a suitable length of 3mm dia plastic rod or wood dowel into the bottom bearing cup on the frame and offer the frame to the hull. Ensuring that everything is upright and square, where the 3mm dia rod touches the keel, mark with a pencil and drill a 4mm dia hole to take the rudder post tube.
Ensure that the hull sits level in the stand, tape the rudder frame into position, drop the rudder tube through the drilled hole and then insert the rudder post and rudder - these last two are not glue yet - just fitted 'dry' to help align the tube. Now make sure that the rudder frame is vertical, drop the rudder tube down so that it just touches the top of the rudder when the rudder is packed up by 1mm from the frame.
All should be nice and vertical now so a healthy helping of 5 minute epoxy was added to the joint between tube and hull inside the hull. Once that has had a good 24 hours to dry, it will be reinforced with fibreglass resin.
A few shots to illustrate :
