Author Topic: Replacement for Planet tx@ rx  (Read 6775 times)
gerard
« on: August 15, 2016, 01:15:11 pm »
I hope you will be able to help me with getting a new tx @ rx. At the moment I have Planet T5 trans and receiver. For my next boat I was going to get a Planet T7, could you suggest a replacement for  this, I have limited monies but could get up to about £80. Thanks Gerard.
spearfish99
Re: Replacement for Planet tx@ rx
« Reply #1 on: August 15, 2016, 01:20:55 pm »
barriew
« Reply #2 on: August 15, 2016, 06:10:26 pm »
How many channels do you require?
Barrie
gerard
« Reply #3 on: August 15, 2016, 10:01:14 pm »
hi Barrie , I think I would require at least 6
Gerard
barriew
« Reply #4 on: August 16, 2016, 07:10:26 am »
Gerard
If you can manage with 6 channels, then I recommend this one (or in its Flysky Guise)
http://www.hobbyking.com/hobbyking/store/__62710__Turnigy_TGY_i6_AFHDS_Transmitter_and_6CH_Receiver_Mode_2_.html
A really solid transmitter with a choice of receivers, some with telemetry. 12 model memory, variable end points, etc.  Tx and Rx for less than £40.
If you need more than 6 then the i10 offers 10, but at greater cost - approx £135.
Barrie
spearfish99
« Reply #6 on: August 16, 2016, 04:25:13 pm »
There is only one possible fly in the ointment, depending on how far away you expect to operate .  This from a review on Hobbyking
 "Very good little radio set for the money. All soldering inside satisfactory, wiring tidy and gimbals smooth in operation. Full channel failsafes. Display is nice and clear, and all switches fall to hand well. RX is very small, has nice long twin antennae with the ends well protected, but is clearly marked 'Park Flier' so no long distance with this gear!!!
  Given that in aircraft models they talk about 100metres for park fliers, probably enough for most people but just needs to be borne in mind
Jack D
« Reply #7 on: August 16, 2016, 04:57:18 pm »
I'm using a flysky Fs-i6 now.
I also use a planet T7 and honestly, I'm finding the flysky to be a meteoric upgrade. It has memory for a number of models (wheras the T7 has none) and it is very easy to reverse channels, much moreso than the planets, because the channel numbers are listed on screen AND on your receiver).
The system also has limited telemetry capability, so the screen shows you TX voltage, RX voltage and also %error in the signal, which essentially warns that you're going out of range. On the water today I got to 200m before the signal error suddenly started jumping from more than 1% (although it does climb very quickly when it does!).
Also, the aerial is moulded in and therefore is essentially indestructible, which is a massive bonus if you don't have a dedicated case for your TX. I was forever knocking the end of my planet off.
It's pretty cheap at around £50 from most places and new RX's are about a tenner. I'll be picking up a few spares while they're still around so I can run my whole fleet off of it.
barriew
« Reply #8 on: August 16, 2016, 05:49:07 pm »
I haven't had any range problems with mine either.
I have found this receiver is slightly smaller than the two usually sold for the i6 and its a pound or so cheaper. It does't offer any telemetry at all, but that's not something I really need.
Barrie
FlySky FS-R6B 2.4Ghz 6CH AFHDS Receiver for fs i6 i10 T6 CT6B TH9x
gerard
« Reply #9 on: August 16, 2016, 06:22:49 pm »
Thanks for all your replies just the information I reqd. will get one ordered. never get more than 100 mtrs have trouble seeing it that far away.
Gerard
Jack D
« Reply #10 on: August 16, 2016, 07:08:00 pm »
I'm mainly going to be using telemetry for a ketch I'm building. It's going to have a sail winch which draws half an amp idle, along with a backup brushless motor. Given the battery I can fit in it is relatively small and I tend to sail for at least an hour and a half or more at a stretch, I will really do with a model voltage warning!
inertia
« Reply #11 on: August 16, 2016, 07:25:56 pm »
http://www.hobbyking.com/hobbyking/store/__97587__Turnigy_TGY_i6S_Digital_Proportional_Radio_Control_System_Mode_2_White_.html
Comes with two receivers. Other colours (i.e. Black) are available.
This is not a recommendation; I'm just passing on some information which was sent to me. Suit yourselves, m'ducks.
DM
gerard
« Reply #12 on: August 17, 2016, 12:28:13 am »
One more question with regard to the TRY -i6 , are the stick controls both spring loaded , if not are you able to convert.
Thanks Gerard
barriew
« Reply #13 on: August 17, 2016, 07:16:14 am »
Gerard - no they are not. There are two version available Mode 1 and Mode 2, but one stick is non centered in both modes. I don't know of any conversion, but haven't really looked.
Barrie
sparkey
« Reply #14 on: August 17, 2016, 09:08:08 am »
 :-)) Its the right stick on mode one :-)) .
nivapilot
  • re-invented rc boater
« Reply #15 on: August 18, 2016, 08:57:07 am »
FlySky FS-i6....can be "upgraded" to use ten.....yes 10...channels
I use a "park fly" Gr3e , 3 channel rx in my converted "workboat", and go the full 150yds up the lake, with no loss of signal,
others at the same lake lose their signal in certain places on the lake, but I have not found it yet.
Spare gimbals are available from BangGood for less that £6.00
My i6 has full 10 channel capability and has both gimbals set as self centring...can't fault the system so far.
« Reply #16 on: August 18, 2016, 09:45:31 am »
Interesting!  - Part No.?
nivapilot
« Reply #17 on: August 18, 2016, 11:14:26 am »
http://www.banggood.com/Flysky-FS-i6-2_4G-6CH-Transmitter-Spare-Part-ThrottleDirection-Main-Bearing-Seat-p-1058191.html?cur_warehouse=CN
They also do a replacement screen, motherboard, antenna mount and a three hole balance bar for it as well.
