Author Topic: Talacre - short on power  (Read 3721 times)
Buccaneer
« on: August 17, 2016, 08:47:17 pm »
I have just completed a Caldercraft Talacre Coaster that I picked up on EBay and today gave it it's first Sea Trial. Basically it goes alright but I require full power to get even a reasonable speed from it. It came fitted with an MFA Geared Motor, 11:1 Ratio, and a 36mm four bladed propeller. I have fitted a 7.2V 4300 mAH Battery Pack and an Action P80 ESC. The maximum prop size I could fit would be 44mm. If I were able to remove the motor, which looks like a somewhat doubtful option, I have an MFA 2.5:1 which I could slot in, or I am considering a Mabuchi 555.
I have a number of other Tugs and Merchant ships so I have a rough idea of what performance looks right but this one definitely under performs. I would be interested to hear from other Talacre owners about what they have fitted, or any thoughts from anybody else.
Re: Talacre - short on power
« Reply #1 on: August 17, 2016, 09:04:30 pm »
I have built the Talacre and used an MFA 500 motor direct to the prop with no gears and it went quite realistically on the water.
There is a build blog on here somewhere.  I'll have a look for you.
ken
Kipper
  • Bodgitts Dry Dock Co.
« Reply #2 on: August 17, 2016, 10:12:05 pm »
I have a Billings Nordkap, it's very close to the Talacre's dimentions & runs nicely at scale speed, with a bit of 'oomph' in hand for get out of trouble speed, it's powered by a good ol' Mabuchi 555 on 12v, running a 40mm 3 blade brass prop.
I also have a Model Slipway 'Dutch Courage' tug, it is getting twin Mabuchi 555 power, swinging 60mm 3 blade props in fixed korts & they don't struggle to give above scale speed.  :-))
Your Photobucket pictures are missing!?!
Try direct from your computer as long as they are under 200K.   I find that 150K is satisfactory
 Ken
Im gonna need a bigger shed.
roycv
« Reply #3 on: August 17, 2016, 10:46:13 pm »
Hi Buc...The 555 driving direct will do the job, the gear reduction you have now on a relatively small prop, as you have found, is ineffective.
If you can measure the current taken when prop is in the water you should be looking for about 2 to 3 amps to give 15+ Watts of power.
regards Roy
« Reply #4 on: August 18, 2016, 09:09:26 am »
The previous owner probably thought that if the real thing turned its prop at a given speed, so should the model, hence the rather silly gearing.  The usual advice for better performance is "smaller prop", but in this case a larger prop an a lower gear ratio would be the answer.  For scale looking performance, the techy answer is a scale prop turning at full size speed TIMES the square root of the scale.
Subculture
    • Dive-in to Model submarines
« Reply #5 on: August 18, 2016, 10:07:50 am »
Aim for a shaft speed of 4000-5000RPM. That should give you a decent speed without overcooking things.
« Reply #6 on: August 18, 2016, 10:31:23 pm »
Send me the photos, I'll post them for you!  :-)
« Reply #7 on: August 18, 2016, 10:47:42 pm »
The 2.5 gear reduction should be OK.  11:1 is far too much.
Kipper
« Reply #8 on: August 18, 2016, 11:17:19 pm »
Missing pics  :-)
Buccaneer
« Reply #9 on: August 22, 2016, 08:52:21 pm »
Problem solved, I hope. Thank you to everybody for their contributions, many thinking along the same line as me. I ended up fitting a 3 Blade 40 mm Propeller and the 2.5:1 Motor. Fitting the motor was a 'challenge' (That's the nice way of putting it!) Removing the mounting bracket by undoing the four bolts was not on as these came up through a wooden base that had been epoxied to the hull and two of the nuts were just not accessible by spanner. Then I had a bright idea, why not just change the gearbox. This fell apart when I found out that the gearboxes were fixed with different size bolts. Finally by removing the gearbox, then the retaining ring that holds the motor onto the mount, I was able to extract the motor. Repeat the process in reverse with the 2.5:1 motor and we were there. I just need a calm day at the pond to see how it performs, but whatever the result I think this will probably be as good as it gets.
