Author Topic: 2 motors 1 esc  (Read 3192 times)
MadMax
2 motors 1 esc
« on: September 11, 2016, 04:24:28 pm »
i have a problem that some body on mayhem may be able to me with
2 turnigy D3536.....1250 kv  and 1 5oamp hobby king water colled esc
they will be attached to 2... 35 mil plastic handed props in a hooben perkasa
the boat weighs very little as it is all plastic
                                                 hopeing somebody can help
Re: 2 motors 1 esc
« Reply #1 on: September 11, 2016, 05:03:38 pm »
Assuming wiring is your problem see attached diagram.  :-))
Re: 2 motors 1 esc
« Reply #2 on: September 11, 2016, 05:06:59 pm »
Assuming the motors are brushless, you will need an esc for each.
Klunk
Re: 2 motors 1 esc
« Reply #3 on: September 11, 2016, 05:33:43 pm »
Those are brushless motors. You will need 2 esc's. Period.  On brushed motors you can put 2 motors onto one esc. But on brushless it's a no no. One motor will not work.
Also as you will have 2 esc's it would be worth getting 2 batteries instead of running off one
full time penguin
red181
Re: 2 motors 1 esc
« Reply #4 on: September 11, 2016, 07:35:06 pm »
I have used those motors in aircraft. They have a nice voltage range, to get the perkassa running fast, max the voltage, There are a number of combinations, but one 4 cell lipo per motor/esc would be good, similar to what I did with my PCF Boat.
higher mah means more run time, I would suggest 3000mah upwards to get a runtime of up to 25 mins approx,  (not all flat out though!)depending on budget available. If you use a gell cell, its a bit like having a V8 engine in your car, and running it on chip fat oil!, and nihms wont deliver the power of a lipo. But, you do need a specific charger, and compatible connectors, so some soldering might be required
This might help, these are quite good
http://www.hobbyking.co.uk/hobbyking/store/__8852__ZIPPY_Flightmax_3000mAh_4S1P_20C.html
and my pcf build might help
http://www.modelboatmayhem.co.uk/forum/index.php/topic,47936.0.html
Brian60
Re: 2 motors 1 esc
« Reply #5 on: September 12, 2016, 08:20:36 am »
Not strictly true Klunk. The perceived wisdom of the internet forums is that if the motors are a matched pair they can run from one esc, there are even youtube videos demontrating this very thing.
kinmel
Re: 2 motors 1 esc
« Reply #6 on: September 12, 2016, 08:33:06 am »
My Hooben is running on 2 of those motors ( 2 Esc ) with 35mm plastic props and S3 LiPos give over scale speed. I usually run with a pair of 4000 2S.
steamboat66
  • maybe it will float!
Re: 2 motors 1 esc
« Reply #7 on: September 12, 2016, 08:20:11 pm »
DO NOT rely on this working! some may have GOT AWAY with it, but for reliability, and less chance of "magic" smoke, one ESC each motor.
Page created in 0.117 seconds with 21 queries.
