I asked about intended use because even a warped dowel might have enough straight enough lengths to provide spars. If a longer length is only warped in one direction, it can be successfully used as a working mast if the bend is forward-leaning, the bend being taken out by the backstay tension.
Obviously a nice pristine straight one is best, but on a working model where wear and tear will happen, using what is available, especially if new stock is not easily come by, might be the only viable option. Agian, if the bend is in the manner of a corkscrew, the best fate for it is to be cut into short lengths and used to fasten other large lumps of wood together.
