Hi Justin
This is my setup for all my Hobbyking car ESC's using the program card.
1 Cutoff Voltage 3S=8.7, 4S=11.6 (2.9 per cell). This is the only change I do in the setup when changing Batteries.
I recommend a voltage alarm(Hobbyking part No. Voltage-Alarm( the black ones).
These also check total voltage and each cell voltage.
2 Start Power Percent 10%
3 Advance Timing 4(I have used this on these motors B28-57-17L 1700kv, B28-5715L 1900kv, 2836-3700kv,Trackstar 17.00T 2400kv, 3639-750, 3639-1100, D3548/4 1100, 3648-1450 and XK3674 1900).
4 Run Mode(2)
5 Brake Force (1) 50%
6 Drag Brake Force (1) 0%
7 Neutral Force 8%(default)
8 Initial Brake Force (1) 5%
9 Reverse Force (1) 25%
