Author Topic: 6 Channel R.C  (Read 1794 times)
gyjoe
6 Channel R.C
« on: October 17, 2016, 02:30:41 pm »
Hi Guys
           Wonder if someone could explain,From what I understand channels 1/2 are used for Steering & engine speed.
Can I use other channels for example,turning on or off navigation light,and if so what do I need a special switch connect them up?
Is there some sort of switch I can buy to make this possible
As you can see I'm new to all this
                                            Many thanks
        Joe w c
nivapilot
  • re-invented rc boater
Re: 6 Channel R.C
« Reply #1 on: October 17, 2016, 03:15:53 pm »
Provided we are talking a stick transmitter and not a wheel tx
on four channel Transmitter using mode 2, (throttle on left stick) mode 1 uses throttle stick on right.
  "A Mode II RC transmitter controls the aileron (roll) and elevator (pitch) with the right hand, while the rudder (yaw) and throttle are controlled by the pilot's left hand."
left stick usually controls throttle (ch3) and ch4 anything else that requires a proportional input/output
right stick usually rudder (ch1) and ch2 again a proprtional input/output.
on a six and upwards transmitter there are switches that control anything you need to (I have a ten channel transmitter)
If you wish to switch on any lights and devices they would need to be switched from the reciever via a RC switch, turnigy do them, including a 7 channel switcher, or you can find them on e-bay, around £12 - £21.
If you want to switch via  a stick, you would need a latching switch, (one that switches on at a given position of the stick input, latches on and switches off again when the same stick is positioned to the same position again)
CGAux26
Re: 6 Channel R.C
« Reply #2 on: October 17, 2016, 06:20:18 pm »
I use a Turnigy switch to turn on/off my smoke generator.  On the Spektrum DX-6 TX it's a simple on/off switch at the top of the radio.  Works great.  Hobby King sells them, too.
JimG
Re: 6 Channel R.C
« Reply #3 on: October 17, 2016, 09:31:36 pm »
The simplest way to switch electrical components is to use a servo and a microswitch. A disc servo output can be shaped into a cam to control more than one switch/
Jim
Dundee Model Boat club
inertia
Re: 6 Channel R.C
« Reply #4 on: October 17, 2016, 11:09:29 pm »
Joe
Welcome to Mayhem and the 21st century!
You may find the following a little more useful than such outmoded electro-mechanics http://www.action-electronics.co.uk/pdfs/Relay%20Switches.pdf
and http://www.action-electronics.co.uk/pdfs/Switches.pdf
These products, as well as others previously mentioned, are all available even north of Berwick-upon-Tweed.
DM
gyjoe
Re: 6 Channel R.C
« Reply #5 on: October 19, 2016, 01:25:10 pm »
Thanks to all you guys,this information as helped.I have just purchased a Turnigy switch which seems to work perfectly
                                             joe w craggs
