Author Topic: Silver or Soft (Solder)?  (Read 3132 times)
tonyH
« on: November 04, 2016, 05:17:19 pm »
Hi All,
I'm just sorting the plumbing on the current project and setting out the exhaust side from the engine.
I've been looking at the threads about oil separators and many of the photos show the pipework to be silver soldered on the (hopefully) very low pressure side of the plant.
So...is silver soldering necessary?
Tony
coolbumble
Re: Silver or Soft (Solder)?
« Reply #1 on: November 04, 2016, 09:35:43 pm »
Hi Tony
I don't think you need any solder The one I have came with plastic /rubber piping and works with no problem just a metal plug in the drain pipe.
Enclosing pic of my set up Sorry its a little Fuzzy !
Ian http://www.modelboatmayhem.co.uk/forum/Smileys/Tug/thumbup.gif
tonyH
« Reply #2 on: November 05, 2016, 05:22:50 pm »
Thanks Ian,
I thought that it was a bit of overkill but................ %)
Tony
xrad
  • Keeper of the Sun Dried Tomato
« Reply #3 on: November 06, 2016, 02:59:49 pm »
'soft' solder comes in various heat ranges just like silver solder.  I like to 'easy' silver solder the steam exhaust header flanges due to heat and sometimes for stress, but not pressure (unless it is a compound engine).  For soft solder, I use highest temp I can find at local hardware store, not low temp electrical.....
steamboatmodel
« Reply #4 on: November 07, 2016, 05:34:33 pm »
One solder I have found useful is "Stay Bright" or its generic version. It is 5-7% silver not high enough for pressure work, but very good for mechanical joints.
Gerald.
Be wary of strong drink. It can make you shoot at tax collectors--and miss. Lazarus Long
tonyH
« Reply #5 on: November 07, 2016, 09:09:12 pm »
Thanks all,
I've taken the usual compromise route and used normal silver solder for the first couple of joints and I'll run with higher temperature soft solder for the rest. It's a bit complicated because the separator does actually have a cold water pipe running through it but I'll mix and match to suit.
