Author Topic: LED Calculator  (Read 3808 times)
david48
LED Calculator
« on: November 07, 2016, 05:02:12 pm »
 I found this web site ,some will know it .https://www.kitronik.co.uk/blog/led-resistor-value-calculator      .I am on with trying to make up a fibre optic board  for Fairmount Alpine .  If the long leg is + is the flat on the LED -   I could be wrong but I thought that if the legs are the same length the flat was + . The last batch I bought from Comp Shop ,the long leg is on the opposite side to the flat . Is it me !!!
Thank all for the help
David
g6swj
  • Short Wave Jammer! -.-
Re: LED Calculator
« Reply #1 on: November 07, 2016, 05:07:01 pm »
From Sparkfun website...
The longer leg, should indicate the positive, anode pin. Or, if someone’s trimmed the legs, try finding the flat edge on the LED’s outer casing. The pin nearest the flat edge will be the negative, cathode pin.
Jonathan
david48
Re: LED Calculator
« Reply #2 on: November 07, 2016, 05:13:02 pm »
It was me ,just set up a warm white with 100ohm all looking good applied power PIFPAFPUF .I will try again 19 left .
thanks Jonathan
David
NFMike
    • Plague Marine Services
Re: LED Calculator
« Reply #3 on: November 07, 2016, 05:55:02 pm »
My way to remember is:
The long leg is because you need more to make a +
And the flat is a bit missing, or subtracted ... -
I expect there's a clever rhyme somewhere but I can never remember them.
TheLongBuild
  • Build em, and play hard..
Re: LED Calculator
« Reply #4 on: November 07, 2016, 06:02:27 pm »
If using the correct voltage can you blow an led if you reverse the polarity ?, if not just exchange the wires until  it works..
cos918
Re: LED Calculator
« Reply #5 on: November 07, 2016, 07:33:43 pm »
thanks Jonathan
David
What voltage are you using . for 12v I would go from 700 ohm to 1 k ohm
john
Kipper
  • Bodgitts Dry Dock Co.
Re: LED Calculator
« Reply #6 on: November 07, 2016, 11:28:36 pm »
thanks Jonathan
David
Using the calculator you referenced above, for 1 'warm white' 5mm LED, on a 12v battery, it gives a resistor of 470 ohm as the preferred value, so only using a 100 ohm resistor will cause it to go "PIFPAFPUF"  {-)
If only using 6v, you need a 150 ohm
Im gonna need a bigger shed.
Re: LED Calculator
« Reply #7 on: November 08, 2016, 08:26:21 am »
LEDs have their forward voltage drop at a range of currents to give their glow.  They also have a maximum reverse voltage.  Exceeding either the forward current or the reverse voltage will kill them.
If uncertain as to which leg is which, connect two in reverse parallel, connect to a suitable voltage supply through a suitable resistor.  One will light.  That one is how they should be wired.  Since the forward voltage is always lower than the max reverse voltage, the one that didn't light up can be reconnected and reused.
RAAArtyGunner
Re: LED Calculator
« Reply #8 on: November 08, 2016, 09:14:38 am »
Now that is a handy tip  O0  :-))
david48
Re: LED Calculator
« Reply #9 on: November 08, 2016, 11:49:59 am »
Thanks for the help and input gentlemen , it was me , No 1 I picked up the wrong resistor .No2 I failed to cut the track on the strip board where I had the resistor ,in effect track by passed the resistor ,a obvious over sight , I should have known better . Redid it all this morning all good now .
David
Page created in 0.046 seconds with 21 queries.
