Author Topic: Fixing motor shaft to prop.shaft?  (Read 3336 times)
tizdaz
  • Boom!
    • My RC TID Build
« on: November 10, 2016, 11:04:32 pm »
How does the motor shaft attatch to prop shaft? Ive read about couplings, does the shaft on a motor have a flat edge to prevent the shaft/coupling from spinning loose etc?
My large-scale TID Build Website:
http://www.tizdaz.co.uk
Facebook:
tizdaz
  • Boom!
    • My RC TID Build
Re: Fixing motor shaft to prop.shaft?
« Reply #1 on: November 10, 2016, 11:21:02 pm »
Im guessing its this that i need:
http://www.mobilemarinemodels.com/large-safety-coupling-974-p.asp
But how does this attatch to motor shaft?
Facebook:
david48
« Reply #2 on: November 11, 2016, 12:12:22 am »
With a grub screw  the small end pushes in to the silicon tube
« Reply #3 on: November 11, 2016, 05:34:13 am »
One of the first pages on Mayhem, from many moons ago...
http://www.modelboatmayhem.co.uk/My_models/01%20piranha.htm
tizdaz
  • Boom!
    • My RC TID Build
« Reply #4 on: November 11, 2016, 07:45:57 am »
Ah ok cool, i see the flat spot on prop shaft, is there also meant to be a flat spot on the motor shft for the grub screw ?
Cheers :-)
Facebook:
« Reply #5 on: November 11, 2016, 08:47:37 am »
You will need to file a flat spot on both the motor and shaft
« Reply #6 on: November 11, 2016, 08:51:57 am »
In practice, there should always be a flat to associate with a grub screw, although grubscrews do come with a variety of ends, some capable of forming a dent in whatever they are fixing to.
Some prop shafts have a threaded inboard end - the intention there is to use a coupler insert that is similarly threaded.
NFMike
« Reply #7 on: November 11, 2016, 09:34:57 am »
As you'll have gathered from the above there are a multitude of systems to get from motor to shaft. Pragmatically, just get the motor you want/have and shaft you want/have, see what ends they have and get a coupling (of the type you want) that has fixings to suit. As said, for a grub screw you may decide to file a flat if there isn't one already.
You don't have to have the same fixing at both ends of the coupler - a thread to the shaft and grub screw to the motor is very common.
imsinking
« Reply #8 on: November 11, 2016, 09:54:49 am »
Motor shafts are normally plain Dia , some prop' shafts can be plain too, as said grub screws are required , don't super glue or loctite the adaptor's, on you'll have to destroy them to get them off .
Bill
tizdaz
  • Boom!
    • My RC TID Build
« Reply #9 on: November 11, 2016, 10:53:14 am »
oki doke, thanks again for info, will wait until i pick them up & see whats what, if the motor shaft is all round, then i will probably file a flat spot for the grub screw to prevent the motor shaft from spinning loose :)
Facebook:
NFMike
« Reply #10 on: November 11, 2016, 11:47:50 am »
... , don't super glue or loctite the adaptor's, on you'll have to destroy them to get them off .
But do consider loctiting any grub screws. If they work a fraction loose, they unscrew very quickly to the 'no drive' position.
tizdaz
  • Boom!
    • My RC TID Build
« Reply #11 on: November 11, 2016, 06:23:48 pm »
Aye will do, thanks again guys :-)
Will let you know how i get on when i start the build thread, be a few weeks yet as the hull is being made, its only been 2 weeks but feels like ive been waiting 6months already! lol :-(
Facebook:
