Author Topic: Multimeter  (Read 6082 times)
tizdaz
Multimeter
« on: November 15, 2016, 02:00:29 pm »
Hi guys,
Im looking to buy a multimeter, it will be to test voltage upto around 24v and also amps upto 50ish
Ive seen a few on ebay but not sure which one i need?
g6swj
  • Short Wave Jammer! -.-
Re: Multimeter
« Reply #1 on: November 15, 2016, 02:47:39 pm »
A general purpose meter like this would be a good start
https://www.amazon.co.uk/d/Electrical-Tools-Testers/Pocket-Digital-Multimeter-Proster-Ranging-Multimeters-Tester/B015Z451ZY/ref=sr_1_4?ie=UTF8&qid=1479220836&sr=8-4&keywords=multimeter
The catch with most of these is that they will not measure anywhere near 50amp! - Read the small print
Perhaps get a general purpose meter and then a "current meter" from Component Shop  - see this page
http://www.componentshop.co.uk/catalogsearch/result/?q=meter&cat=0
They also have a general purpose meter @£6
Or if you have deep pockets and want a Rolls Royce - Google "Fluke"
Jonathan
NFMike
    • Plague Marine Services
Re: Multimeter
« Reply #2 on: November 15, 2016, 02:50:52 pm »
 You won't get 50 amps on a cheap, or even expensive, standard mm. I bought one of these which does volts, etc, as well via included leads:
https://www.amazon.co.uk/gp/product/B00O1Q2HOQ/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
That's from Amazon. I tried to get the same thing from ebay first but it turned out to be one of those 'UK' sellers where even the second one never arrives but in the interim "please give us positive feedback as it will be with you soon".
I've been happy with it and it's probably my main meter now.
tizdaz
Re: Multimeter
« Reply #3 on: November 15, 2016, 04:46:16 pm »
Hiya guys :-)
I think i may have asked for wrong info in terms of amps!
My setup will consist of 4x 12v 20Ah batterys that im going to wire up using Parallel/Series, so i want to measure the total voltage and Ah so i can make sure all is good as i should be getting around 24volt and 40Ah, hope this is a bit more clear!
Also what size AWG wire should i use to link the batterys up, im guessing 14 Awg?
Thanks guys :-)
g6swj
Re: Multimeter
« Reply #4 on: November 15, 2016, 05:02:13 pm »
Perhaps it's worth considering a permanent fixture in your model in which case something like this would be good. This way you can monitor performance over time - it can even record min and max so you can see history when boat returns to shore.
http://www.componentshop.co.uk/150a-watt-meter-and-power-analyser.html  - It can measure real time, min and max - check the specs
You can only measure the current drawn in "amps" in a working circuit - i.e. the motors need to be running ( and to get a true figure boat needs to be in water, props attached etc)
You will need to protect things with strategic fuse placement
Re cable size/length/voltage drop/current capability etc etc loads of charts on the net e.g. http://www.24volt.co.uk/info/Wiring/Wiring - I would over spec this a little to allow some tolerance
Jonathan
Buccaneer
Re: Multimeter
« Reply #5 on: November 15, 2016, 05:34:18 pm »
Concerning your Multimeter I think it's another case of you get what you pay for. I have blown a couple of cheap Maplins ones so moved up to the £30 range. The present one is the Uni T UT151C at £29.99. I have the predecessor UT 50 and find it excellent.
Re: Multimeter
« Reply #6 on: November 15, 2016, 05:44:55 pm »
Measuring voltage is easy, hook up a voltmeter with a range that maxes out at a higher voltage than expected.  Most general purpose multimeters will do this.
There is no direct way of measuring the AH figure for a battery.  With an Amp meter and a clock and a log book you can estimate how much energy the battery has been offered (some expensive chargers do this with magic electronics).  Knowing how much you can get back is a different story altogether, especially with SLA batteries, even more if they are being used at a current discharge rate greater than their stated rate.  Their capacity is usually specced at a 10 hour discharge, or increasingly often, a 20 hour rate.  The faster they discharge above that rate, the less efficient the conversion of energy.
cos918
Re: Multimeter
« Reply #7 on: November 15, 2016, 05:51:52 pm »
there are meters that can measure the current in a SLA battery . act make them . we have them at work. waste of time and money as they are not reliable . I can get several different reading out of the same battery . Best way is to measure your max current pull . so if thats say 10ah . you should be getting 3.5 to 4hours . as this get less and less time for new batteries
john
tizdaz
Re: Multimeter
« Reply #8 on: November 15, 2016, 06:50:17 pm »
Oki doke, thanks guys great help :-)
grendel
Re: Multimeter
« Reply #9 on: November 15, 2016, 08:45:31 pm »
I have a fluke and that is only capable of 10A as standard, above that you need to plug a shunt in to take the majority of the current away from the meter.
Martin [Admin]
Re: Multimeter
« Reply #10 on: November 15, 2016, 09:13:56 pm »
Thinking of buying a Multimeter?
See:
  https://youtu.be/uFTQxWlMGeE
tizdaz
Re: Multimeter
« Reply #11 on: November 18, 2016, 12:10:05 am »
hiya guys :)
ok still trying to figure out what thickness wire i need to get, my motor is a 24volt 150watt, i think ive worked out that it shouldnt be pulling more than 7amps max, looking at a chart it says for 7 amps i should use 14 AWG, does this sound correct?
Also is this the AWG i should use for connecting my batteries up in parallel/series as well as to the motor?
RAAArtyGunner
Re: Multimeter
« Reply #12 on: November 18, 2016, 02:01:56 am »
Jonathan
Which is what I have but was a gift.
NFMike
Re: Multimeter
« Reply #13 on: November 18, 2016, 09:21:34 am »
hiya guys :)
You should size the cable to the fuse protecting it, not the expected 'normal' current (which should be somewhat less of course).
So work out max current expected in use, pick a fuse to comfortably exceed that, select cable to handle that current.
Trawlerman-Les
Re: Multimeter
« Reply #14 on: December 18, 2016, 04:55:27 pm »
My old Tandy moving coil meter has died after forty plus years, so I've bought one of these from Wickes. Schneider seem to be a large respected company so I took a chance.
 http://www.wickes.co.uk/Schneider-Digital-Multimeter/p/119803
Hope I've done the right thing?
Les
Re: Multimeter
« Reply #15 on: December 19, 2016, 11:10:43 am »
Can't go wrong with that Sir.   Just the job.     :-))
Ron Rees
Re: Multimeter
« Reply #16 on: December 19, 2016, 04:10:27 pm »
Oh the good old days when you touched the battery leads to your wet tongue!!.....What laughs we had....!
Ron Rees
Re: Multimeter
« Reply #17 on: December 19, 2016, 04:11:28 pm »
Or better still....got your apprentice to do it!!
Re: Multimeter
« Reply #18 on: December 19, 2016, 04:13:56 pm »
Remember lighting fags by putting wire wool
across the terminals and it quickly glowed red :}
Trawlerman-Les
Re: Multimeter
« Reply #19 on: December 19, 2016, 04:44:49 pm »
Oh that's brought back some memories from over 50 years ago! Me and my old school pal, who I still see occasionally, used to call into Woolworths on the way home from school. In those days you bought items from separate counters. The battery counter was our regular stop where we would see which of us could short out the biggest battery with our tongues, before being told to sod off! Oh happy days!   %% %%
grendel
Re: Multimeter
« Reply #20 on: December 19, 2016, 06:24:18 pm »
just one comment, dont ever try that with an old 90v radio battery, I had a headache for about 2 days after, even though it was half dead and only managed about 40v.
Re: Multimeter
« Reply #21 on: December 19, 2016, 09:35:51 pm »
Quote..............
"Oh the good old days when you touched the battery leads to your wet tongue!!" .....
OK, with AA & C & D cells etc, why does this work only with the fingers left hand touching the negative end of the battery?...... and the tongue ....it's universal  O0
Some where in the grey matter someone suggested the left hand is a shorter route [circuit] to the heart  :o
NFMike
Re: Multimeter
« Reply #22 on: December 19, 2016, 10:15:55 pm »
Except that the heart is actually in the middle - not on the left.
Re: Multimeter
« Reply #23 on: December 20, 2016, 09:06:14 am »
Probably something to do with layout of the actual plumbing and where the main artery departs the heart before it branches out.
[/size]Blood pressure readings are invariably taken on the left arm.
[/size]The electricity, once it has got through the (fairly insulating) layer of skin, flows best through the wet conductive stuff, and the arterial path on the left side is probably shorter.  Add to that, the right hands skin on a right handed person is probably that bit tougher due to having had more use, and insulates better.
Re: Multimeter
« Reply #24 on: December 20, 2016, 09:53:11 am »
Text quotes from Malcolm as below........
"Blood pressure readings are invariably taken on the left arm"
"The electricity, once it has got through the (fairly insulating) layer of skin, flows best through the wet conductive stuff, and the arterial path on the left side is probably shorter.  Add to that, the right hands skin on a right handed person is probably that bit tougher due to having had more use, and insulates better
For some unknown reason, the left arm bleeds better than the right :-))...........
