Author Topic: solder free glue  (Read 3142 times)
Rottweiler
solder free glue
« on: January 06, 2017, 03:49:16 pm »
Has anyone used this stuff and does it work please.If it does work it must be a bargain at £4.79 inc from USA
Mick F
Re: solder free glue
« Reply #1 on: January 06, 2017, 04:13:23 pm »
Not me.... look forward to your review Mick!   :-))
Rottweiler
« Reply #2 on: January 06, 2017, 05:18:47 pm »
Not ordering any until I hear the results!
With my shaky hands it may be a bit easier than trying to hold a soldering iron still enough to solder anything lol
« Reply #3 on: January 06, 2017, 05:35:21 pm »
There are some reviews here:
https://www.amazon.co.uk/d/DIY-Tools/Conductive-Wire-Glue-Paint-Soldering/B00SRIITQ4
Probably a second best solution but never hurts to have another arrow to your bow. Just like solder paint, magic for soldering up railings neatly.
cos918
« Reply #4 on: January 06, 2017, 07:31:16 pm »
Hi Mike
what are you going to be using it for
john
Rottweiler
« Reply #5 on: January 06, 2017, 08:40:52 pm »
Thanks for that Colin,Im still not sure but worth a try maybe!
John,
I was thinking of using it for attaching wires and resistors to leds,as they really are difficult for me,s is most things where i need a steady hand these days.
As for the stuff advertised in Colins link,in a syringe,I have some of this and was told it was silver solder,it was a craft ring maker who gave it me.She said to use a fine high power flame on it,and not to use much of the paste.I have tried this a few times,and each time it has turned into a sort of powdery grey dust,and done nothing at all in the way of soldering the item together,I was trying to make a railing at the time.Yet a soldering iron wont even melt the stuff!
As you can see I am not too good at this sort of thing.
Mick
« Reply #6 on: January 06, 2017, 09:54:30 pm »
Mick,
I didn't mean that link for the solder paint actually, sorry.
The stuff I am using is Carrs 188 http://www.anticsonline.co.uk/533_1_1399097.html I bought some for about a tenner at Squires last year, I think they still had some in stock last week when I was in there.You just paint it on around the joint and apply an iron, it seems to have a lower melting point than wire solder and just sinks into the joint and tins the adjoining wire. Absolute doddle provided the wire is clean, I just rub it with a bit of abrasive paper. Recent work below.
(sorry to go temporarily off topic!)
« Reply #7 on: January 14, 2017, 04:15:44 pm »
Not something for a long term installation but great pondside for a quick repair or for mocking up
roadrunner440
« Reply #8 on: January 14, 2017, 06:48:14 pm »
have you considered solder paste?when I converted my boat from dome leds to surface mount leds and surface mount leds I found this invaluable..use a toothpick pull a string out after you stir it up. cover the joint...touch a solder iron to it till it turns sliver and your done
I used mostly 1206 chips but for the deck lamps I used 5050 chips. those are nice a 3 100ma bright white led's in 1 5mmx5mm sized chip.be warned that you have to have 3 separate powers and 3 separate grounds see results below the 5050's are the 2 on top of the wheel house
[url=http://][/urhttp://www.ebay.com/itm/1pcs-42g-MCN-300-Soldering-Solder-Paste-63-37-25-45um-B217/330691478075?_trksid=p2045573.c100506.m3226&_trkparms=aid%3D555014%26algo%3DPL.DEFAULT%26ao%3D1%26asc%3D38530%26meid%3D5da57dc333214d8384efc65b18d7aab2%26pid%3D100506%26rk%3D1%26rkt%3D1%26l]
[url]]][/urhttp://www.ebay.com/itm/1pcs-42g-MCN-300-Soldering-Solder-Paste-63-37-25-45um-B217/330691478075?_trksid=p2045573.c100506.m3226&_trkparms=aid%3D555014%26algo%3DPL.DEFAULT%26ao%3D1%26asc%3D38530%26meid%3D5da57dc333214d8384efc65b18d7aab2%26pid%3D100506%26rk%3D1%26rkt%3D1%26l]
[url]
https://www.youtube.com/watch?v=B8vGAhOt4Po&t=124s
Rottweiler
« Reply #9 on: January 14, 2017, 09:11:28 pm »
Thanks for all the replies,much appreciated.
I have decided not to try it,but have now gone for some solder paste in a syringe,as recommended by my pal John,and  a few others of you.
I have also found a cheap source of ready wired leds,and will be using these in future,purely for convenience.They are also available with resistors pre soldered,to the voltage you require. it may be a little more expensive,but not when you ruin as many as I have with my soldering lol!
Thanks again
Mick F
roadrunner440
« Reply #10 on: January 14, 2017, 11:29:55 pm »
just depends on how much you want to spend.i found the prewired too expensive..i got 2000 leds in 10 colors for 50$us from ebay..the magnet wire I scrounged from automotive relays and scrap electronic's from  vcr 's to coffee makers. anything that goes into a wall outlet has a transformer of some sort wound with magnet/enamled wire...so I had plenty to practice with...good building :}
tizdaz
  • Boom!
« Reply #11 on: January 14, 2017, 11:53:09 pm »
your RC Boat must make blackpool illuminations look like kiddys stuff! :D ...j/kiddin lol :)
My large-scale TID Build Website: http://www.tizdaz.co.uk/forum
Facebook:
roadrunner440
« Reply #12 on: January 15, 2017, 01:46:28 am »
https://www.youtube.com/watch?v=B8vGAhOt4Po&t=126s
not that bad but I do ok I can see where im going.. :-))
tizdaz
  • Boom!
« Reply #13 on: January 16, 2017, 06:52:04 am »
Very nice, night sailing brings a whole new dimension and fun to models with good lighting i think :)
cant wait until mine is completed & do some night sailing :D
Facebook:
roadrunner440
« Reply #14 on: January 17, 2017, 01:18:01 am »
thank you very much..i agree..i origanly had 5mm dome leds for lighting and was not happy with it...then 1 burnt out and I hated the idea of going with the same old thing...so I researched smt surface mount leds..very easy to work with...they evan have sidemounted leds although I haven't got any yet,but they are on the list..i think they would make great sideboard lights....also the abilty to mount them almost anywhere is the bestespecialy if you use surface mount resisters with them..also I like to run wireless when I can using brass tube/contacters&brass strip
Page created in 0.094 seconds with 22 queries.
