Author Topic: battery leakage  (Read 1066 times)
Rottweiler
battery leakage
« on: January 08, 2017, 09:04:50 pm »
Im good at asking silly but genuine questions!!
Here goes
My non rechargeable batteries which were sadly left in one of my old radios has leaked.I have thrown the batteries away of course but the connections in the radio have turned green gungy stuff.
I would like to salvage the radio if I can,so what do I use to neutralise the green verdigris whatever its called.someone said vinegar,but I am very loathe to use it as it is acidic itself?
Many Thanks
Mick F.
jarvo
  • Etherow model boat club
Re: battery leakage
« Reply #1 on: January 08, 2017, 09:21:24 pm »
Hi Mick, try an alkaline such as baking soda, mix as a slight paste and wipe it on, make sure to completely cover the contacts, wash off if pos, or wipe clean several times, depends how bad the damage,
Mark
Tugs are for pulling
chas
Re: battery leakage
« Reply #2 on: January 08, 2017, 10:36:13 pm »
If you can remove the battery holder / contacts from the rest of the transmitter, pour nearly boiling water over the contacts. the gunge will vanish.  follow with one of those plastic pan cleaners, and all should be ok.
Chas
RAAArtyGunner
Re: battery leakage
« Reply #3 on: January 09, 2017, 12:12:37 am »
Take a very close look at any attached wires/wiring as they may also be affected.
