Author Topic: JJC VOSPER MTB PE308 Proportional Master Unit MK2  (Read 1656 times)
TheLongBuild
  • Build em, and play hard..
« on: January 12, 2017, 11:03:07 am »
HI
I have picked ones of these up recently, do you need anything else apart from a speaker , battery, ESC to make them work ?
g6swj
  • Short Wave Jammer! -.-
Re: JJC VOSPER MTB PE308 Proportional Master Unit MK2
« Reply #1 on: January 12, 2017, 11:38:54 am »
So long as it's the master it will work standalone - master has large ali heatsink on board
If you want a copy of original instructions then I can copy for you.
Jonathan
TheLongBuild
« Reply #2 on: January 12, 2017, 11:46:52 am »
If the instructions in the picture I have those as it was BN still sealed in the box.
Just on some posts about it else where they mention about it requiring a sound blaster ?. I thought one of those was the big stereos you carried on your shoulders in the 70's and 80's   :}  or was that a getto blaster...
g6swj
« Reply #3 on: January 12, 2017, 11:53:36 am »
There is normally a single staple at the top holding the plastic wrapper closed.
Yes the pale blue front cover doc folds out and has all the instructions in.
The confusion seems to be with the "Master" and the "Slave" - as the title on both packages are "Vosper MTB Engine Sound" and then at the bottom either "Proportional Master unit" or "Proportional Slave" - the slave has no onboard amplifier!!
PS You are probably aware they can run hot - a small fan may prolong it's life...
Jonathan
TheLongBuild
« Reply #4 on: January 12, 2017, 11:58:54 am »
I must have had a special box I Had a staple top and bottom  %%
Thanks for the info and the tip about the fan, will make sure one is attached before use.
Larry
Page created in 0.101 seconds with 21 queries.
