Model Boat Mayhem - Forum
Author Topic: Johnson Dark horse motors  (Read 1443 times)
« on: August 19, 2007, 03:54:17 PM »
Right I have seen quite a few of these sold on ebay recently and wondered if anyone out ther has used them a sI am considering buiyng some for my Yorkshire man any comments cheer s
Welsh_Druid
Re: Johnson Dark horse motors
« Reply #1 on: August 19, 2007, 04:16:50 PM »
If you mean those 600s with flux rings there are two in my trash box you are welcome to.  B- - - - - awful current hungry things.
Don
« Reply #2 on: August 19, 2007, 04:20:03 PM »
In a word Stav, DONT.
Not unless you want your tug to leave your Perkassa standing.
They are fast motors but VERY power hungry.
If you use them at all run on 6 volts with a heavy ESC.
On 12 volts they kill ESC's easily as they draw horrendous current.
Why not try the recommended geared motors?
On 12 volts they run at aprox 19000 rpm, but as stated on here previously the stall current is OVER 100 amps EACH.
« Reply #3 on: August 19, 2007, 04:23:37 PM »
Stavros,
The geared 500 motors should power the yorkshireman with decent brass props.
Andy_k
« Reply #4 on: September 12, 2007, 06:51:34 PM »
Can always try the model motors direct they supply the 777 motor bearing at each end 7poles run really smooth and at 6v will turn a 50mm prop and only draw something  like 5amps amazing motors and the same size as a 540  O0
Right which one will I do next?;)
