Author Topic: Popovka restoration  (Read 9588 times)
Akira
Re: Popovka restoration
« Reply #25 on: March 03, 2019, 02:17:29 pm »
Beautiful master! What is the material, it looks like Renshape? I like how you are approaching ballasting, It will look like original plating.  Are you planning on your armament being operational?
« Reply #26 on: March 03, 2019, 02:28:38 pm »
Hi Akira,
The material is called 'Chemiwood' though other names like Modlab are also used for some grades. I imagine that Renshape is a similar wood flour/resin compound that can be machined, turned etc.
My approach to the ballasting is because there isn't a huge amount of space for stuff inside because of her shallow hull and the baulks of balsa used to create the hull shape. The hull is so buoyant!
I will make the barbette traverse but the guns run up slopes on firing, so decided to keep things less complicated. More detail and less action!
Akira
« Reply #27 on: March 03, 2019, 03:58:27 pm »
Excellent!
