Author Topic: Flat sheet dive vanes  (Read 2319 times)
U-33
  • K-157 Vepr. Akula-11
« on: February 10, 2017, 10:02:26 am »
The dive vanes on the Jelly Bean are made from flat styrene sheet, with the operating rod made from brass rod. The plan suggests to simply epoxy the rod to the plastic sheet...that would probably work ok, but I'd like to make a stronger joint of it. Any ideas, lads?
craggle
  • Boaty McBoatface
Re: Flat sheet dive vanes
« Reply #1 on: February 10, 2017, 12:36:31 pm »
Could you cut the planes from 2mm sheet copper or brass and solder the rods to it?
Be nice and strong then but a bit heavier if mass is an issue.
Craig.
Model Slipway Envoy tug built.
Huge Lifeboat under construction.
Fred Ellis
« Reply #2 on: February 10, 2017, 02:19:21 pm »
 Just drill a small hole in the rod then push a brass rod through the rod and the dive vane.
unbuiltnautilus
« Reply #3 on: February 10, 2017, 03:13:42 pm »
'L' Bend in the outer section of the brass. Then sandwich TWO sheets of plastic, top and bottom. Cyano and clothes peg together. Then sand to a nice smooth finish..nice!
U-33
« Reply #4 on: February 10, 2017, 03:18:39 pm »
Thanks Fred...good thinking. Hadn't thought of that.
And thanks Alan...I like that one.
« Reply #5 on: February 10, 2017, 04:29:36 pm »
Hi Rich,
Alan's way would also streamline
the plane , Good :-))
It doubles the weight though,  :embarrassed:
if extra weight aft could be a problem
If JB can take the weight, that's wot eye
wood do. 8)
unbuiltnautilus
« Reply #6 on: February 10, 2017, 06:52:46 pm »
Then one servo for the left plane, one for the right plane, and run it all through a V Tail mixer function, "xxxxx" about with the C of G and see if you can do a barrel roll...no, tried it with my Deep Dive many years ago, silly idea as it turned out!
U-33
« Reply #7 on: February 10, 2017, 08:10:06 pm »
I can remember Dave Stevens (a mate of Bernie Wood's) doing that with a scratchbuilt submersible, it went all over the place, he gave up in the end.
Dr.Schmidt
« Reply #8 on: February 10, 2017, 10:24:54 pm »
Take a Dremel with a cutting wheel and cut a slit into the brass rod. Stick the planes into the slit and then glue it into position.
« Reply #9 on: February 11, 2017, 12:31:01 pm »
Or on a similar plane (pun not intended) cut the slit, and solder a thin sheet of brass as a fixer with holes like a ladle and then epoxy two thin sheets of styrene - one above and one below - the holes - to reduce weight and allow the glue to connect both styrene sheets together, profile to suit.
U-33
« Reply #10 on: February 11, 2017, 01:04:03 pm »
Thanks to my old friend Pete (subman) the dive planes are now well and truly sorted. Top and bottom rudders from a Revell Skipack...spot of filler, quick rub over with the wet n' dry...proper job.
Thanks Pete.... I owe you one.
