Author Topic: Aerial wire length...  (Read 4931 times)
U-33
  • K-157 Vepr. Akula-11
« on: February 18, 2017, 06:49:41 pm »
Anyone know the correct length for the aerial wire on my Robbe/Futaba FPR-138DF 40 mhz receiver, please?
MotorFlote build log : https://www.modelboatmayhem.co.uk/forum/index.php/topic,15222.0.html
Re: Aerial wire length...
« Reply #1 on: February 18, 2017, 07:51:30 pm »
A metre should work near to optimum Rich
Unless someone measures one and lets you know.
U-33
« Reply #2 on: February 18, 2017, 07:56:19 pm »
I guessed it was somewhere around a metre, Ned...I'll solder it up to a metre and do some range check before I let loose.
« Reply #3 on: February 18, 2017, 09:04:20 pm »
Rich,
Just measured an old Futaba 40 meg receiver and it is exactly 94cm.
Bob K
  • Bob K
« Reply #4 on: February 18, 2017, 10:26:10 pm »
Interesting thread on RC Groups . . .
https://www.rcgroups.com/forums/showthread.php?1078426-RX-aerial-length
A lot of length variations listed, especially for Futaba Rx's.  It does say length for each model is critical as "This as Futaba receivers have an input inductor that matches the original length of wire antenna, as listed below, to the respective receiver RF circuits".
See thread for details of lengths per receiver type.
« Reply #5 on: February 19, 2017, 05:16:41 am »
From what I have read in the past, antenna length is somewhat important, but not critical. You can go into optimal length, optimal arrangement (straight vertical). Both my boats have the antenna horizontal running around inside the hull (far from straight) and work fine.
Unless you are going to extremes of range,(800m plus), where you could not really see the model, I doubt if it would affect most of us model boaters. The main exception I can think of is 2.4G that will not pass through water, so that sailing a boat in a good swell might need an above deck antenna.
U-33
« Reply #6 on: February 19, 2017, 07:53:20 am »
Bob, Bob and TT...thank you for the comments, gentlemen...much appreciated.
regiment
planet t 5
« Reply #7 on: April 05, 2017, 02:43:53 pm »
my deceased  mate son has just given me a boat  with a t 5  planet tx rx    the rudder channel is ok but the sail channel stops after a couple of seconds any body got any ideas
Page created in 0.01 seconds with 15 queries.
