Author Topic: What sealant?  (Read 2725 times)
tonyH
What sealant?
« on: February 27, 2017, 08:48:46 pm »
Hi All,
I'm fitting up the steam plant for the current project, something I haven't done for years.
As far as I remember, I've used all sorts of sealant for the boiler fittings in the past, from PTFE tape, through Plumbers Mate and I've found a bottle of TRULoc 271 which I think I used.
What do the jury think is best?
As a minor afterthought, I've also got to solder a couple of non-functioning handles onto the funnel. Is low melting (290 degree) silver solder likely to be OK or do I need to go to the 600 degree version?
Tony
steamboatmodel
Re: What sealant?
« Reply #1 on: February 27, 2017, 11:04:45 pm »
Hi Tony,
I have used mostly PTFE tape, but have also used Plumber sealant and sometimes have had joins tight enough that copper or aluminum washers was enough. About the funnel it depends on how hot it gets, does it have a liner? I would think that that 290 degree should be OK.
Gerald.
Be wary of strong drink. It can make you shoot at tax collectors--and miss. Lazarus Long
Jerry C
Re: What sealant?
« Reply #2 on: February 28, 2017, 12:23:23 am »
Copper washers (annealed) should be enough.
Jerry.
tonyH
Re: What sealant?
« Reply #3 on: March 04, 2017, 08:19:58 pm »
Thanks each,
Unfortunately copper washers won't work with the fittings as there's no back to compress against.
I've used a high temperature threadlock/sealant and tried a steam trial last night which seems to work up to normal (40psi) pressure so I'll report further whan I've re-set the safety valve to 60.
I've bitten the bullet regards the funnel and used 600 degree silver solder just in case!
Tony
ooyah/2
Re: What sealant?
« Reply #4 on: March 04, 2017, 08:56:35 pm »
Tony,
Use Lactite 243 thread lock, it will withstand any temp and pressure that you can put on it, it's Blue in colour and comes in 10 ml bottles , used sparingly it lasts a long time, I never use anything else and have done so for the past 20 years.
George.
tonyH
Re: What sealant?
« Reply #5 on: March 05, 2017, 12:13:04 pm »
Hi George,
I've used SAS 243 which I think is the same spec. as the Loctite. I think I got it years ago with a boiler/engine from John Hemmens and it seems to be rated to the same temp.
Only time will tell!
Tony
steamboat66
  • maybe it will float!
Re: What sealant?
« Reply #6 on: March 05, 2017, 08:03:30 pm »
i got some sas with my clevedon steam plant. i used it on everything that needed sticking or sealing.
ooyah/2
Re: What sealant?
« Reply #7 on: March 05, 2017, 08:08:00 pm »
Yes guys  they are all good, remember you only need a spot on the threads.
George.
Page created in 0.112 seconds with 23 queries.
