Author Topic: rc narrowboat first build  (Read 2492 times)
paulg
« on: March 11, 2017, 06:39:40 pm »
After buying old rc boats and bringing them back to there glory i'm now buying a narrowboat hull and starting from scratch  %%
i have an idea of what electrics to buy but would like to know what you would recommend please, motors, esc units, etc etc
one question i would like to ask is should i fit a bow thruster as the hull is 78inch long ?
cheers
Re: rc narrowboat first build
« Reply #1 on: March 12, 2017, 02:02:50 am »
My thoughts.
If you are going to get into spots that are narrower than your turning circle, away from you, a bow thruster (although not scale) would help you. But will you have enough draft? Even with a flat bottom, you could do some clever piping, but it would complicate things.
If the tight narrows are closer to you, a three point turn is doable as you can see what you are doing. Or you can pretend to be a man and horse and just swing her around with a pole.
MartinL
  • Founder member Westham Ocean Racing Yacht Club
« Reply #2 on: March 12, 2017, 06:25:38 am »
I would certainly put a thruster on a narrow boat of that length, mine is only 40" but a windscreen washer pump in bow certainly makes it a lot more fun on the lake.
Martin
Plastic-1
« Reply #3 on: March 12, 2017, 06:33:37 am »
Where would you sail a narrowboat? I've always thought they look a bit odd/out of place in open water - I suppose I'm used to seeing them trapped in canals.
paulg
« Reply #4 on: March 12, 2017, 09:12:10 pm »
thats a bow thruster on the cards then  :}
i sail my boats (steam and electric)on the old northernparts of Lancaster canal as there are no big boats on that stretch and very few people
MartinL
« Reply #5 on: March 12, 2017, 10:53:07 pm »
Sure beats the ponds we down here have to use. I,m envious.
Martin
paulg
« Reply #6 on: March 12, 2017, 11:17:35 pm »
open to information on what would be the best motor and esc for a boat this size ? was wanting to use 6v or 12v battery
Page created in 0.233 seconds with 17 queries.
