Pages: 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 ... 52   Go Down
Author Topic: MMM Portgarth build  (Read 252076 times)
T33cno
Re: MMM Portgarth build
« Reply #50 on: March 24, 2017, 12:11:04 pm »
Re the bow thruster.
The Athon I bought had a leaking bow thruster because the self tapping screws supplied had caused the housing holes to crack.
To avoid this on my new one I will discard the supplied screws and drill/tap 3mm to accept  SS M3 pozidrives.
T33cno
« Reply #51 on: March 24, 2017, 05:29:02 pm »
Experienced opinion required please.
The MMM plans are non specific of a profile for the rear of the skeg.
This is where I'm at now, am I anything like expected?
Channel
    • Channel Images
« Reply #52 on: March 24, 2017, 07:35:22 pm »
Portgarth's skeg was increased in size from the original build. This picture shows the original and how it was extended forward and deepened.
Follow my blog - www.channelimages.com
T33cno
« Reply #53 on: March 24, 2017, 09:01:28 pm »
« Reply #54 on: March 24, 2017, 09:22:45 pm »
There seems to be a problem with your pictures not showing. They may be too large for the forum.  If, however they are hosted, then that is where the problem may lie.
T33cno
« Reply #55 on: March 24, 2017, 09:27:40 pm »
Please email to watersa@ntlworld.com and I will host & post it  :-))
Channel
    • Channel Images
« Reply #56 on: March 25, 2017, 07:51:27 am »
Photos from my PC. Have moved to different photo storage site, here you go:
T33cno
« Reply #57 on: March 25, 2017, 07:56:52 am »
Thanks Channel but the skeg is in darkness  <:(
Thanks for the email Chris super pics  :-))
T33cno
« Reply #58 on: March 25, 2017, 08:04:53 am »
Motor mounts now set on Sikaflex 221
Bushes for Korts used as alignment tools 8mm to 8mm
T33cno
« Reply #59 on: March 25, 2017, 08:54:49 am »
Had to spend far too much time filling pin holes in these Korts  >:-o
I think I'm going to stick with the primer colour and satin clear coat over this
What do you think?
T33cno
« Reply #60 on: March 25, 2017, 11:33:10 am »
New toy
T33cno
« Reply #61 on: March 25, 2017, 12:23:28 pm »
That worked out a treat thanks Ken
timbo
« Reply #62 on: March 25, 2017, 12:31:11 pm »
Like the new toy,  I've been lookingbat them on flebay.
T33cno
« Reply #63 on: March 25, 2017, 12:59:01 pm »
Screwfix 120
timbo
« Reply #64 on: March 25, 2017, 01:06:48 pm »
Cheaper than flebay  :-))
T33cno
« Reply #65 on: March 25, 2017, 01:20:19 pm »
Tidy
T33cno
« Reply #66 on: March 25, 2017, 01:51:02 pm »
I can see now that there isn't a very straight centre line in the hull moulding at the bow. Perhaps it has always been this way or just tired?
I like complete symmetry so some hard sanding and filling in order.
T33cno
« Reply #67 on: March 25, 2017, 02:39:40 pm »
Starboard side inverted, perfect
Port side tom tit
T33cno
« Reply #68 on: March 25, 2017, 03:22:58 pm »
What fantastic weather today for cracking on  :-))
T33cno
« Reply #69 on: March 25, 2017, 06:12:55 pm »
This is the Halfords red primer topped with clear satin lacquer. I think it'll do.
I've pinned the skeg with stainless steel servo pushrod rather than brass as suggested by MMM
This is before pushing home and glueing with Zap A Gap
T33cno
« Reply #70 on: March 25, 2017, 09:15:35 pm »
Moving on from the bow and how it lacks symmetry and quality of finish either side of the centre line. The stern is just as bad if not worse. This picture doesn't fully capture how poor it is and I can't stand it like it is!
 so much Isopon is going to be needed to satisfy. Not what I expected from a ready made hull that cost as much as a full size bath tub.
This again is the PORT SIDE as if it's a poor copy of the starboard.
Any other Portgarth builders suffered this?
T33cno
« Reply #71 on: March 25, 2017, 09:53:15 pm »
I'm happy with my work. Skeg is rock solid  :-))
One more pass of P38 and a coat of Z-poxy resin will see it ready for primer
T33cno
« Reply #72 on: March 26, 2017, 05:53:40 pm »
T33cno
« Reply #73 on: March 26, 2017, 05:59:52 pm »
Just a tiny bit of filler to finish the rectification once the primer is hard.
T33cno
« Reply #74 on: March 26, 2017, 06:04:19 pm »
A different view. Next the Korts and Anchor whatsits
Pages: 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 ... 52   Go Up
