Pages: 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 ... 51   Go Down
Author Topic: MMM Portgarth build  (Read 208615 times)
Re: MMM Portgarth build
« Reply #225 on: April 08, 2017, 10:19:59 PM »
That is becoming a fine Tug hull Andy. Do you make many paxolin 'coins' at work?
Re boat stands, two suggestions I have read here and in Model Boats are:
1: Plasticine strip stuck onto the hull (wipe any grease from plasticine off hull before painting) then removed and used as template to draw around.
2: Flexiruler for similar results.
3: Profile gauge for similar results.
4: Using offcuts from relevant wooden frames as templates.
Ok, that's four suggestions  %) But three of them are similar  %%
T33cno
« Reply #226 on: April 08, 2017, 10:22:17 PM »
As many as I need in any size  {-)  and thank you  :-))
T33cno
« Reply #227 on: April 08, 2017, 10:25:18 PM »
She's getting a bit tasty now but not getting her bum wet today
All electrics are functioning and bow thruster is smooth
T33cno
« Reply #228 on: April 08, 2017, 10:38:04 PM »
Fore deck fits but not the least bit symmetrical
I guess it's not so noticeable unless you flip it the other way  :o
T33cno
« Reply #229 on: April 08, 2017, 10:42:58 PM »
Those two stringers form the length of the revised access hatch otherwise servicing the motors and couplings would be impossible
Paul2407
« Reply #230 on: April 09, 2017, 07:01:26 AM »
Looking very nice, can I ask what material do you use to mount your electrics on?
T33cno
« Reply #231 on: April 09, 2017, 07:03:30 AM »
Paxolin
Paul2407
« Reply #232 on: April 09, 2017, 07:05:27 AM »
Paxolin
Thank you, seen you mentioned that a few times in the thread I thought it was a glue  %%
T33cno
« Reply #233 on: April 09, 2017, 07:13:04 AM »
I get it from work but I've found small quantity suppliers mine is 6mm thick tho
http://www.brimal.co.uk/5-0mm-paxolin-srbp-insulation-board-a4-size.html
Paul2407
« Reply #234 on: April 09, 2017, 07:39:07 AM »
Very handy to have a source from work  :-)) I've just bought a small quantity to start with from the link you gave, if you need any bearings at any time miniatures/thrust bearings etc... anything bearing wise I can help you with that I was a car mechanic, but for the last 12 years I'm now a bearing consultant
T33cno
« Reply #235 on: April 09, 2017, 07:45:36 AM »
So far I've used it for :-
The motor mounts
The battery mounts
The stern tubes bulkhead
The electrics platform
reinforcements
waterproof and works with superglue resins and PU adhesives, sand the surface first
needs no painting
Paul2407
« Reply #236 on: April 09, 2017, 07:49:30 AM »
Sounds perfect, do you drill it and use nuts bolts? Or can you screw directly to it with a pilot hole?
T33cno
« Reply #237 on: April 09, 2017, 07:55:11 AM »
Drill & tap it. I superglue 4mm SS nuts between it and circuit boards purely as a spacer. I fix with M3 SS allen screws.
Paul2407
« Reply #238 on: April 09, 2017, 07:58:40 AM »
Sounds good stuff I can't wait to give that a try
T33cno
« Reply #239 on: April 09, 2017, 08:00:52 AM »
The action electronics black boxes are fixed with double sided tape (from work)  {-)
T33cno
Paul2407
« Reply #241 on: April 09, 2017, 08:15:01 AM »
I've got screws, washers and nut's & bolts coming out my ears down here, I've probably got enough to last me a lifetime I used to buy loads from my 1/8th car racing days and it's cheaper to buy in baulk but I buy most of mine from a company called seascrew in Eastbourne he's an good friend of mine that I've known for many years
T33cno
« Reply #242 on: April 09, 2017, 04:52:38 PM »
Good to go apart from I'm missing two servo rod connections  >>:-(
Running the bath now  :-)
T33cno
« Reply #243 on: April 09, 2017, 04:53:33 PM »
T33cno
« Reply #244 on: April 09, 2017, 05:11:48 PM »
Leffe blonde to toast her  :-))
T33cno
« Reply #245 on: April 09, 2017, 05:21:26 PM »
Paul2407
« Reply #246 on: April 09, 2017, 06:10:55 PM »
is that with 1 or 2 batteries in? still pretty high if just the one
T33cno
« Reply #247 on: April 09, 2017, 06:14:46 PM »
Both all in so loads of scope
T33cno
« Reply #248 on: April 09, 2017, 06:25:28 PM »
Skeg is just nicely deep enough to protect the Korts  :-))
T33cno
« Reply #249 on: April 09, 2017, 06:28:28 PM »
Found another servo/tiller arm thingy so did the link bar and set the unthreaded end in 5 min resin
Pages: 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 ... 51   Go Up
