Author Topic: MMM Portgarth build  (Read 186343 times)
T33cno
Re: MMM Portgarth build
« Reply #1025 on: January 03, 2018, 08:46:04 PM »
Well done Graham
Yes I have throughout repeatedly drilled and taped it
Starting with my motor mounts and all the hatch fixings
« Reply #1026 on: January 03, 2018, 11:08:55 PM »
Paxolin is bloomin hard!
T33cno
« Reply #1027 on: January 03, 2018, 11:24:39 PM »
I use a wood cutting blade in my makita 18 volt jigsaw
Drill with HSS bits
Sanding is hard so cut accurate to minimise the need
Abrade surfaces to be glued or painted, only needs matting off.
T33cno
« Reply #1028 on: January 11, 2018, 07:50:38 PM »
I currently have cause to be using P38 and I've been waiting for the opportunity to do an alteration to the inflatable boat I bought from MMB. Ideal dimensions but completely flat bottomed.
So I CA'd a strip of brass down the centre line and filled. This didn't give quite enough angle so I glued another strip of brass on top and repeated.
Just one of many changes to come around a basically sound building block.
Now fits the cradle much better like the real one.
T33cno
« Reply #1029 on: January 13, 2018, 02:29:30 PM »
D shape styrene strip seemed to stick OK with poly cement
T33cno
« Reply #1030 on: January 14, 2018, 09:29:14 PM »
Spray cover added.
It's very difficult finding any one example that fits the bill so this will be a product of imagination. A few more details to add but the paint should transform it.
tizdaz
« Reply #1031 on: January 14, 2018, 10:29:06 PM »
Very nice work fella, keep it up! :)
T33cno
« Reply #1032 on: February 23, 2018, 08:25:22 AM »
Thanks Daz
Nice to see the thread is being used for reference as the view count keeps on climbing despite my inactivity  :-))
The weather seems a long way from being warm so I still cannot do the lacquering. I have no motivation to finish the metalwork until then and I'm busy with other things.
I'd like to think I can make it to Balne Moor 4th March with her just for viewing and the social.  8)
tugnut
« Reply #1033 on: February 23, 2018, 08:46:54 AM »
Hi Andy boat still looking good love the Rib :-)) ,is Balne on the 4 April .
regards John B
T33cno
« Reply #1034 on: February 23, 2018, 09:01:53 AM »
regards John B
Thanks John
No itís
http://www.modelboatmayhem.co.uk/forum/index.php/topic,60152.msg633523/topicseen.html#msg633523
Then 8th April
Butts
  • Secretary, Balne Moor Model Boat Club
    • http://balne-moor-model-boat-club.myfreesites.net/
« Reply #1035 on: February 23, 2018, 11:12:07 AM »
regards John B
John, as Andy has told you the first Balne Moor event is 4th March.  That though is a free sail not a dedicated tug tow event.  The 8th April is first dedicated towing event.  Having said that, there will be a tow in the water at all of our events, so the opportunity to tow is always there.
Coming along nicely as always Andy.  Is it going to get it's bum wet towing at Balne sometime soon? :-))
T33cno
« Reply #1036 on: February 23, 2018, 12:10:49 PM »
Not until the deck is lacquered
I donít want to undo my good work with water ingress for the sake of a little patience  :-)
Definitely on the pull this year  :-))
Butts
« Reply #1037 on: February 23, 2018, 05:08:51 PM »
I understand perfectly Andy. For similar reasons it might be a bit longer before
my winter build sees the pond.  Won't be there on the 4th anyway.
poll
« Reply #1038 on: February 23, 2018, 08:42:06 PM »
 I'll be there Andy to give you some pointers .😁😁
Tafelspitz
  • Model Boat Bedlam
« Reply #1039 on: June 18, 2018, 01:59:21 PM »
What may have happened to T33cno and his formidable build?
We live in a society exquisitely dependent on science and technology, in which hardly anyone knows anything about science and technology.  Carl Sagan
captain bligh
  • Boats oh'd av um
« Reply #1040 on: June 18, 2018, 02:01:24 PM »
Was only thinking the same the other day!
It's not a bad man who makes a mistake its a good man who can get over it.
« Reply #1041 on: June 18, 2018, 08:58:37 PM »
Andy still puts info and videos up on Facebook but left the forum a few months back.
Butts
« Reply #1042 on: June 19, 2018, 09:15:41 AM »
Andy is a member of Balne Moor MBC and recently he had a go at tug towing.
His boat performed well as can be seen here.  It is not quite finished yet though.
neverupright
« Reply #1043 on: June 28, 2018, 03:02:47 PM »
Hi Michael
see you have an event on at Balne this Sunday what time does it run from and what time is it expected to finish.
Carl
Butts
« Reply #1044 on: June 28, 2018, 03:36:20 PM »
Hi Carl,
The event will start at about 10.30 and run until 16.00ish.
The gates are kept open on event days so you'll have no problem getting in.
Hopefully see you sometime on Sunday :-))
Michael
Taranis
  • Kirklees MBC/ Balne Moor MBC
« Reply #1045 on: November 04, 2018, 10:09:29 PM »
Still not finished but not forgotten and sailed quite a bit this year. Other projects in the way.
Some pictures to view.  Tyres recently added to port side to prevent damage when docking
ANDY
Happy modelling since Jan 2017
MidWest Lobster boat
My Portgarth
Taranis
« Reply #1046 on: November 13, 2018, 10:32:14 PM »
Thanks Ian. That is the deck house, I've yet to start the wheelhouse  :-))
Just bought this Bosch rather than a proxxon vac. £162 delivered from Czech republic
Bosch GAS 20 L SFC
18 months now and this vac has worked its nuts off. It's very important to clean the filter frequently for best performance. I have just this evening bought another filter for swapping out so I can continue and service the old at leisure.  Cheapest filter I could find was from Germany at just over £20 delivered. I never use a vacuum bag as it seems completely unnecessary.
When used purely for my craft room I have my Proxxon bench sander plugged into the vac so it starts stops via the sander switch
How you liking yours Mark T ?
BTW the very best price I can find today is £193 delivered but some sellers go to £343  {-) <*<
ANDY
My Portgarth
Taranis
« Reply #1047 on: November 21, 2018, 06:39:32 PM »
Portgarth revisited.
I've decided to take a break from lifeboats and spend some time progressing this to a happy conclusion.
Long have I avoided the stair and deckhouse roof railings due to the plans being so wrong. I know whatever I do they won't be right but worse with none at all.
So firstly I cannot solder in place without damaging finished paint, to minimise this I have made a template drilled on my pillar drill that I can flip over to do both sides.
The template is used to pilot drill the stanchion holes in place and then to solder them away from the location.
At the same time trying to leave maximum width on stairs that are too narrow. It will only be possible to do the outboard rails as simply not enough room for rails both sides.
ANDY
My Portgarth
Taranis
« Reply #1048 on: November 22, 2018, 11:40:28 AM »
A tool tip without intending to teach egg sucking.
I bought this sometime ago from Leeds Model Shop surprisingly cheap.
My proxxon (dremel ) electric drill on flex shaft is just too difficult to control and I could foresee the merit of this Archimedes that takes up to 2mm bits
To drill through the template not shown. (previous post)
If all goes well my railings will be a purely interference fit to the deck without adhesive just like the wheelhouse roof and mast
ANDY
My Portgarth
Taranis
« Reply #1049 on: November 22, 2018, 04:47:37 PM »
The template is working great as a soldering jig. A couple of stanchions can be soldered in situ without damage to paint then transferred to the jig for remaining work. Moving back and forth between site & jig to check and adjust.
Here I hope you can see how I have cranked the stair rail outwards to the first stanchion that has a 90 bend at the top. This creates an illusion that the stair is wider than it is.
Some minor adjustment to make but the rest of the cross rails can now be soldered off site
Photo by Kevgarth
ANDY
My Portgarth
