April 29, 2024, 11:16:38 am
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Mayhem at Wicksteed -
May 25, 26
Home
Help
Search
Calendar
Login
Register
The Shipyard ( Dry Dock ): Builds & Questions
Lifeboats
Gluing problem
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: Gluing problem (Read 3275 times)
lesfac
Full Mayhemer
Offline
Never too late for a happy childhood
South Wales UK
Gluing problem
on:
March 31, 2017, 03:38:43 pm »
I was under the impression that the laser cut parts in my Speedline kit were made from perspex and could be glued with a solvent applied to the edges. However I have found that some of the laser cut sheets are in a white plastic type material and I have found that it does not react at all with a solvent. The solvent works fine with clear perspex but not on the white stuff in the kit.
Can anyone shed any light on this? Am I using the wrong solvent ?(although it is a proprietary brand that works on clear perspex)
I notice on the photos of the build by Terry Small, the parts I am talking about were clear perspex but they are now white. Has Speedline changed the material?
If I cant use a solvent what alternative Glues are available that suit edge to edge bonding?
Les
Administrator
Full Mayhemer
Offline
Peterborough, UK
Re: Gluing problem
Reply #1 on:
March 31, 2017, 04:25:12 pm »
Ask Adrian, Flundle (Speedline Models)
Giant Models
pipster
Full Mayhemer
Offline
Re: Gluing problem
Reply #2 on:
March 31, 2017, 07:01:39 pm »
I think the white plastic for the wheelhouse is abs. I had the same problem using ema plastic weld to glue it but have now discovered deluxe's plastic magic and that works loads better.
Phil
gerard
Full Mayhemer
Offline
Preston
Re: Gluing problem
Reply #3 on:
March 31, 2017, 11:54:50 pm »
Hi Les, I found that the solvent that is used for joining abs plastic plumbing waste pipes,used sparingly, will join in a few seconds. Gerard
Full Mayhemer
Offline
Re: Gluing problem
Reply #4 on:
April 05, 2017, 09:34:13 am »
I have replied to an email from Les regarding this issue. I use acrylic mostly but HIPS and ABS sometimes. All these glue OK and Les has sent me samples from his kit.
I recommend Plastic Weld (Dichloromethane) but itself is funny stuff. If you leave the top off the bottle the active agent in the bottle evaporates leaving the undiluted fluid in the bottle behind so you don't notice. Keep the top on as much as possible else the glue becomes 'tired' and that may be the problem and indeed that is what I expect to find with the samples Les is sending me arrive.
I'll post on here to keep you informed.
Adrian
grendel
Full Mayhemer
Offline
Canterbury, Kent, UK
Re: Gluing problem
Reply #5 on:
April 05, 2017, 12:58:34 pm »
for ABS acetone is a good solvent (I use it on the parts from my 3d printer to stabilise the laminations).
craggle
Full Mayhemer
Offline
Boaty McBoatface
Horsham, West Sussex
Re: Gluing problem
Reply #6 on:
April 05, 2017, 02:58:35 pm »
I used Tensol 12 on the white parts in my Kit Adrian and that seemed to work fine. We both bought our kits at the same time so suspect it's the same material.
Craig.
Model Slipway Envoy tug built.
Huge Lifeboat under construction.
lesfac
Full Mayhemer
Offline
South Wales UK
Re: Gluing problem
Reply #7 on:
April 15, 2017, 04:31:54 pm »
It seems that the solvent I was using although a proprietary item and stated as suitable for abs was less than aggressive on abs. It did work quickly on perspex. I have now bought a different solvent and it has done the job.
Les
Print
Pages: [
1
Go Up
« previous
next »
Lifeboats
Gluing problem
