Author Topic: How do I cut a 3mm slot in 1mm plastic?  (Read 16982 times)
Re: How do I cut a 3mm slot in 1mm plastic?
« Reply #25 on: August 27, 2007, 09:45:38 pm »
I would be temped to make a hole larger, use styrene filler, and plant the fitting in the filler before it set, then hide it under the paint.  Sometimes I really am glad that I'm not a craftsman...
There used to be a slotting tool that looked like an engraving tool fitted with what looked like a short piece of junior hacksaw blade with the teeth at the end.  Downside is the end was probably bigger than the holes needed.  Drilling looks the best option, but I would do my initial holes with an Archimedes pin drill, and use the inevitable broken bits to form the slot in an electric drill run at low speed with water for cooling.
PSSHIPS
« Reply #26 on: August 27, 2007, 10:10:55 pm »
Here's a wee snipet. I have used piano wire in a mini power drill for this, as long as you have the piano wire dead straight, put a small length in the drill chuck and just give it a quick waz, without applying too much pressure otherwise the piano wire will bend and the drill will go daft. Give it a try on some scrap and see how ya go.
 Paul...
Bunkerbarge
« Reply #27 on: August 28, 2007, 10:01:17 pm »
How do you paint a 0.5mm hole ?  ???
Like that O0
« Reply #28 on: August 29, 2007, 11:49:34 am »
Still no picture of this hole ... ::)
I had a look at my new metric ruler to see what 1/2 a mill looks like. It's rather small innit.
How about heating up a piece of copper at that size and plunging it into the plastic ??  (In a precise sort of way)
I fit my stanchions by heating them with an Iron.
Cheers...Ken
« Reply #29 on: August 29, 2007, 08:40:12 pm »
Kenny,
Paint still drying on workshop floor, then I have to move everything back.  :(
I thought about a heated wire but I don;t think it would be accurate enough. I have sent for some watchmakers broaches, a set of 12 0.3mm to 0.65. Expo tools. Hopefully these will do the job.
I will post a photo when the job is done, as it is there is no hole to show.
Doug
« Reply #30 on: August 29, 2007, 08:45:50 pm »
Doug
But aren't holes invisible ? Isn't this why you can't paint them ? ??? :-\
« Reply #31 on: August 29, 2007, 09:00:38 pm »
Dicky,
This is getting complicated I'll have to look into it  ;D ;D O0
« Reply #32 on: August 30, 2007, 01:52:28 am »
Kenny,
Does it need to be precise?
It is to locate a component that will be glued in (I presume) to it will be hidden.
And the adhesive will cover a multitude of sins.
As will the final paint job.
HS93 (RIP)
  • I cannot spell , tough
« Reply #33 on: August 30, 2007, 03:12:35 am »
I cut these tonight , Mark hole, use a 0.04 drill protruding out about 3mm ish, hold or tape a straight edge on few drops of water(important)
move the drill from left to right to help stop climb . Di Daaaaaaa   the one on right was the first try not very good
Peter
« Reply #34 on: August 30, 2007, 04:04:22 pm »
As tigertiger implies, the model is only there to keep the paint the right shape.  If it is going to be painted, you will only see the paint, what goes on beneath is your secret.
« Reply #35 on: August 30, 2007, 08:38:26 pm »
HS93/Peter
Thanks for the demo I'll give it a try, when I return from the family wedding this W/E (if not one thing then another).
TT ans Malcolm,
I try to work as accurately as I can (which often is not that accurate) so that I end up with the best I can do. I know that most other people will not spot small imperfections, but to me they look like enormous carbuncles. Each to his own.  8)
Doug
HS93 (RIP)
« Reply #36 on: August 30, 2007, 08:42:02 pm »
Try on scrap first it took a couple of goes, then it was easy.
Peter
FullLeatherJacket
« Reply #37 on: August 30, 2007, 09:00:11 pm »
OK - just came upon this thread and thought it was time to let this suffering stop!
Ref Sentinel - I designed the bl00dy thing and there's no way that you can cut slots that  small - neither do you need to. The brass U-pieces are soldered or superglued upside down onto the stanchions and act as stops when you push the stanchions into their holes in the deck. On the full-size Nellie these U-Pieces are actually mounting brackets which are welded to the deck and the stanchions fit into sockets bolted to the topside of them, so the stanchions don't go into the deck at all. Yep - you can see daylight underneath them.
Crazy way of doing things, but that's Vospers for you.
Doug - if you look at the photos I sent you there's one of the aft deck rails which shows the towing clench and the bases of several stanchions. You can clearly see what I'm going on about from that, mate.
Sorry for the confusion. Off to find a hair-shirt..........
FLJ  ::)
« Reply #38 on: August 30, 2007, 10:09:32 pm »
Dammit no holes to paint then, Danny will be disappointed. :(
omra85
« Reply #39 on: August 30, 2007, 10:23:18 pm »
You can laugh - but when I've perfected my skill .......
There's money to be had in hole painting  :D :D :D :D
http://www.artgallery.com.ua/bigpicture.php?Artist=46&ID=002&lng=it
Danny
 :P
bigH
« Reply #40 on: August 31, 2007, 05:50:12 pm »
 :D  You kept us waiting for that one Dave
FullLeatherJacket
« Reply #41 on: August 31, 2007, 06:02:35 pm »
Sorry, Harry. Like I said, I just tripped over the thread (p155ed again). Itching like hell from this hair shirt, now.
I'm sure Doug is doing a blinding job of his model of Nellie - it's taking him long enough!!
FLJ
BTW It's nice to be away from the Ward Room and back among the living
Sub driver
« Reply #42 on: August 31, 2007, 06:34:37 pm »
Hello folks...In response to DickyD question how to paint a 0.5mm hole..
All you do is get a 0.5mm drill turn it upside down so the blunt end is to be touching the plastic card ..dip this end in the paint you require so as to just cover the end of the drill and then you touch this onto the plastic card and hey presto one 0.5mm hole painted !! simple.
It may take a couple of practice tries to get the right amount of paint on but its easy when you have had a couple of practice goes, I have used this technique when painting very small portholes on a superstructure and it looks very realistic.
Hope this helps Sub.  ;) ;)
« Reply #43 on: September 04, 2007, 07:15:50 pm »
Hi All
Just to clear a few things up. I have had a very friendly exchange of emails with FLJ and we agree that the slots are needed.  O0 He recommends using heat as suggested by Kenny. I will experiment but am still dubious about accuracy (mine). I will also persevere with the drill etc and let you know what I finally use.
Yes the model is taking a long time, I have built 3 others since I started it, but I want to make it as good as I can. FLJ has been very helpful and I am grateful to him, even if he did have me doubting my sanity when he said the slots weren't needed.  :D :o
Any way feel I'm on the home straight now.
Doug
