Pages: 1 2 3 4 [5] 6 7   Go Down
Author Topic: Smit Rotterdam Build  (Read 52709 times)
FrozenRabbit471
  • Long may you big jib draw
    • My Instagram
Re: Smit Rotterdam Build
« Reply #100 on: May 11, 2017, 04:18:51 pm »
When you come to epoxy the inside of the hull, you might consider laying strips of glass cloth in the epoxy between the frames.  This will strengthen and stiffen the planking a little for when you do the sanding and fairing.  OK, it will add a little extra weight but I don't think that will be an issue in a hull like this!  Just a thought.
Great build - not too shabby at all for an "amateur"!  :-)) :-))
Thanks Greg. I'll follow your lead on that for sure. I bought 2 packs of cloth for that reason. I appreciate all the tips I can get. I'm loving this build.
I intend on installing a bow thruster. One guy recommended drilling / cutting a 20mm hole and order a 30mm thruster.
Hope that's good advice.
Terry
Greg
Better to have it and not want it, than to need it and not have it
FrozenRabbit471
    • My Instagram
« Reply #101 on: May 12, 2017, 02:03:35 am »
Hey all,
I was about to plank this side in. The other side is completely done. I won't be ordering my bow thruster until the end of this month. If I complete the planking here, the only access to the cuddy (inner nose of the bow) will be through the top. The top would be open as I only have the decks pinned down. My intention is to prep and cut 20mm holes but order a 30mm thruster. Can all this be done if I close this planking off?
I've also attached a photo. Regardless of the planking stuff, which of the 3 compartments does the thruster typically get installed?
Peter Fitness
« Reply #102 on: May 12, 2017, 05:08:27 am »
Greg's suggestion of laying strips of glass cloth between the frames is a good one, I have done it on all my boats and it certainly strengthens the hull. The added weight is negligible.
Peter.
FrozenRabbit471
    • My Instagram
« Reply #103 on: May 12, 2017, 06:19:31 am »
Peter.
that's the way I will go once I have this bow thruster thing figured out
FrozenRabbit471
    • My Instagram
« Reply #104 on: May 12, 2017, 05:47:23 pm »
I should be shot! Using this lexan reamer on anything other than "lexan" (RC truck plastic body), is sacrilegious in the RC world.
But, hey what the heck. It worked perfect for reaming a 20mm hole on each side for my bow thruster.
« Reply #105 on: May 12, 2017, 10:55:53 pm »
So..... :o does this indicate the thruster will be located a little off axis and toward the bow in compartment 2?........just before you ream this hole....what is the distance athwart ships for the tube?
FrozenRabbit471
    • My Instagram
« Reply #106 on: May 13, 2017, 02:55:59 am »
Hi Derick, your guess is right. It is in compartment 2 and 3/4 toward the bow in that compartment. I cant remember the mm measured, but they are true on each side. I realize i should have gone in compartment 3 but i was too nervous to be messing with the structure in there. Im no horribly off.... I think.
FrozenRabbit471
    • My Instagram
« Reply #107 on: May 13, 2017, 03:12:03 am »
Ahoy :-))
I have a few pics here. You will all throw pie in my face on these pics. Keep in mind, I am a perfectionist, for real!
I majorly messed up on the starboard side planking. In comparison, you can see I did quite well on port.
Before you all make me walk the plank, just know, I'm am still not discouraged in the least. I worked as hard as possible to compensate for the horrible placement and lack of keeping true.
My wife came in the room, as she often does to show interest and cheer me on. When she saw it, she gave me "a look".
The jig was up. I stood up, stepped back and briefly lost all confidence.... briefly.
I strongly considered not posting them as it would have been easy to just post the port side etc. Then I thought about it and concluded that this is a forum to help everyone. If another builder is searching for how not to do planking, well I have those pictures posted here.
So have a look and Post your honest opinions and reviews, for me, and future builders.
Peter Fitness
« Reply #108 on: May 13, 2017, 05:20:02 am »
It's all part of the learning curve Terry O0  It's amazing what some filler judiciously applied, and lots of sanding can achieve.
Peter.
Tiny69
    • Tiny's Modelling Site
« Reply #109 on: May 13, 2017, 07:27:57 am »
It is not like you're building a galleon were the planking has to be perfect.  I would advise that before you start to sand the planking that you fibre glass resin the inside to stiffen up all the planks so that they don't flex when you start to sand back.  have a look at my build log of the Clyde lifeboat to give you an idea of what I am talking about.
http://www.modelboatmayhem.co.uk/forum/index.php/topic,55867.msg600754.html#msg600754
Tiny
T33cno
« Reply #110 on: May 13, 2017, 07:39:47 am »
FrozenRabbit471
    • My Instagram
« Reply #111 on: May 13, 2017, 09:31:24 pm »
 :o That cloth and resin is messy $#!+ I dont care how experienced you are.
« Reply #112 on: May 14, 2017, 12:01:59 am »
There is a first time for everything Terry and it is an interesting shape to plank so do not fret over a few dips and bumps. You got the frames sorted and recovered the upper sides, so you have got the difficult bits sorted so far  :-))
FrozenRabbit471
    • My Instagram
« Reply #113 on: May 14, 2017, 02:33:16 am »
lol, i actually felt drained half way through laying it inside. Took the rest of the day off. haha
« Reply #114 on: May 14, 2017, 11:52:46 am »
The hobby can be draining especially the electrickery. The fittings and weapons are the best bit, but sadly you need a hull and gubbins to carry them around on.
FrozenRabbit471
    • My Instagram
« Reply #115 on: May 14, 2017, 02:32:07 pm »
I am a Jedi Master and shall tame this beast!
FrozenRabbit471
    • My Instagram
« Reply #116 on: May 14, 2017, 04:58:07 pm »
I know I could have epoxyed this compartment  way back in the beginning of the build, but inexperience is at fault. Now I'll know for next time.
Any advise on how the heck to fully coat this compartment now?
bfgstew
  • Comfortably Numb
« Reply #117 on: May 14, 2017, 05:56:45 pm »
Pour it in and swill it around, messy but does the job.
"Give me a ping Vasili. One ping only, please"
FrozenRabbit471
    • My Instagram
« Reply #118 on: May 14, 2017, 06:01:02 pm »
Thought about that. Bottles say 50:50 mix. I guess I'll do the same for the swish! thanks
bfgstew
  • Comfortably Numb
« Reply #119 on: May 14, 2017, 06:29:18 pm »
Add a drop of IPA to the mix, thins it nicely.
May need to experiment.
« Reply #120 on: May 14, 2017, 06:43:26 pm »
India Pale Ale. {-)
david48
« Reply #121 on: May 14, 2017, 06:46:44 pm »
I thought that as well !!!!!!!!!!
David
FrozenRabbit471
    • My Instagram
« Reply #122 on: May 14, 2017, 07:51:00 pm »
Aye, we'll be thown overboard. Ill let you guys know how it works out. If you dont hear from me by tomorrow it means I've stuck myself to the hull. :-))
« Reply #123 on: May 14, 2017, 09:56:56 pm »
Often awkward corners are reinforced by pouring someresin in especially at the bows and stern to beef up the areas of 'Bonkage'.
You will do fine, does your local filling station provide gloves at the pump? If so get a few pairs to kep your hands resin free (unless you have already invested in latex/nitrile ones).
FrozenRabbit471
    • My Instagram
« Reply #124 on: May 14, 2017, 10:00:55 pm »
Well fellas, the inner epoxy and glass cloth application is not elegant that's for sure. But, It's done.
When it's all dry and fully hardened I'll cut off the excess and i guess thats it for the inside for now.
Unless you all have anything to add?
While I'm waiting for the RC components to show up, I'll start in on  the outside.
Ballastanksian, I bought a full box of neoprene gloves. They're a must have!
Terry
Pages: 1 2 3 4 [5] 6 7   Go Up
