Geoff: I think you are right about the long auger, plus the fact someone else was drilling it. The Forstner bit had no problem, although it did get hot quickly at depth.
Warspite: I know you are trying to help, which is appreciated. The whole stack is well dowelled throughout. The new Forstner bit makes all the difference as it is so much more controllable. I am leaning as I go here.
Three Holes !Lots of thought and careful planning. I finally have three holes bored nicely through eight layers of thick plywood. The Axminster DS2 drill stand proved a solid bit of kit, with a nice long drill travel. The Forstner bit also arrived today. The nearest size to 26mm was 1 & 1/16th inch, just under 27mm. So, a little bit of clearance for the one inch stainless tubes, hopefully not too much. Cut cleanly without any “snatch”, although as I went deeper I had to keep retracting it to clear the chippings. No worries with the workpiece clamped down it finally went through into the scrap board underneath. Edges of holes nice and clean, one advantage of boring it through as a set.
PHOTO:
Surprisingly, when I separated the stack and removed the temporary dowels, the tube sets seemed to go through more accurately than I’d dared imagine.
PHOTO:
Well, obviously I can't insert photos in any logical sequence in my text, using Mayhem attachmentsSmugMug ProblemMajor problem with SmugMug: It has cut me offer after trying to fill in my subscription with them, and each time refusing to recognise valid payment details. My Bank has now stopped my card, which is a major nuisance.
SmugMug have cut off access "as my 14 days trial has expired."
