Hi Roy
I seem to remember reading that full size tankers could take several miles to stop from normal running speed
Andy Thanks for the info. based on the 22,500HP and the scale factor of the model only (got to keep it simple ) I guesstimate the models power should be about 45W.
The basis for this is no secret when dealing with displacement and power use the scale factor cubed
Cheers Tom
Hmmm.
I've taken a different tack to work out the power. Back to basics...
I've got 4*35mm diameter props, with a total surface area of 0.00385 sq m.
The props have a 45 degree pitch, so the advance per revolution is 0.11m.
Call it 0.055m with slippage, since a quoted 50% efficiency for props seems quite common.
Therefore, at 2000rpm, the water should be kicked out the back at 1.83 m/s.
This is above the scale speed of 1.3 m/s, which is essential, else it would never reach that velocity.
So, every second, 0.00385*1.83 = 0.007 cubic metres of water (7kg) is accelerated from zero to 1.83 m/s.
This means that the force required, in Newtons, is 7*1.83 = 12.8.
This is a force just under that of a 3lb weight resting in your hand.
If I were to pull the hull at the scale speed, that's the sort of drag I'd expect to feel...I think?
Back to
The Force... the product of 12.8N and 1.83m/s gives me a value of 22W.
This is about half of that of Telstar's guesstimate - so
are inefficiencies and shaft losses really 50% of the deal, even before slippage is taken in to account?
I think what I need to do here is check a motor running one of my props in water, with a greased shaft - both for current draw and rpm. (The hull is not ready for the water yet.) And if it's falling short of at least 6-8W and 2000rpm, then consider upping the voltage. A little.
Thanks for all the thought-provoking suggestions.
