Building from plans and cutting the wood myself.
The frames should have been 5mm birch ply but when it arrived it was the Imperial equivalent which is a tad thicker, as is all of the wood that I ordered.
The keel is 2 X 5mm laminated together from frames 7 to 13 and 4 laminations from 6 onward. Again all oversize due to the wood being Imperial.
Other woods include Mahogany, Lime and a little 4mm ( ish ) birch ply.
Glue will be mostly yellow aliphatic, maybe a little epoxy here and there.
The Mahogany planks for the hull sides and some of the decking will be 9mm X 3mm which I will cut myself, the hull bottom is 3 mm ply due to the full size having a white bottom.
As for varnish, ( eventually ), it will be LeTonkinois.
Mike.
