Pages: 1 2 3 4 5 6 7 8 [9] 10   Go Down
Author Topic: Biggish Aquarama Special build  (Read 51240 times)
Taranis
  • Balne Moor MBC
Re: Biggish Aquarama Special build
« Reply #200 on: September 08, 2020, 04:22:19 pm »
I think it looks superb Mike
Despite doing mine in the bathroom it was still covered in what appears to be dust but I’m going to settle on 3ft scale
If it looks ok from 3ft it will do  {-)
The colour the shine and the inlay make a much bigger impact than some dust can undo  :-))
On my final coat I won’t have the extract fan on and see if it’s any better
ANDY
ukmike
« Reply #201 on: September 08, 2020, 06:14:50 pm »
Evening Andy.
Good thinking, probably the best way to go.
The problem with the size of my boat is that there's quite a large surface area, the dust then has a big target to settle on.
One glimmer of hope  tho' is that after I noticed it this morning I put it outside in disgust. The sun was shining all day on the model and its was quite hot. Have just brought it indoors and much of the inclusions seem to have disappeared, but not all.
I'm going to leave it for a week or so and see if it's acceptable, hope so.
I don't mind having to cut it back, but how to prevent the same thing happening, the answer is defying me.
Mike.
Taranis
  • Balne Moor MBC
« Reply #202 on: September 08, 2020, 06:21:28 pm »
This is why I’m hoping that 0000 wire wool and pure beeswax may fix it but I’ve yet to try
ANDY
Thornej
  • Newbie (for now!)
  • Model Boat Mayhem is Awesome!
« Reply #203 on: March 26, 2021, 12:26:30 pm »
Greetings from downunder.
What an amazing build Mike - awesome skill and work!!  :-))
I am particularly interested to see the amount of time taken to achieve such a first class result.
I am just starting out on a build the same size and without plans I get quite discombobulated as to what to do next and how to do it!  {:-{
You have provided a great example for me to move forward on - Thankyou.
One day hopefully mine will float!
Jeff
Jeff
ukmike
« Reply #204 on: March 28, 2021, 12:41:58 am »
Many thanks Jeff.
No more work done to the boat for several months now as I have to work in my little shed in the garden  mainly to the weather here. Fortunately, it should be warm enough to carry on shortly. There's still quite a lot to due but all being well it should be finished this year.
Very brave of you to take on a Riva Special without any plans, not something I wouldn't attempt but give it a go.
Would love to see a Blog if you do it as many people on here would be very interested I'm sure.
Mike.
ukmike
« Reply #205 on: May 25, 2021, 04:49:39 pm »
Hi.
Big Riva is back on the workbench following the winter layoff.
Have rubbed down the final varnish coat as I wasn't overly pleased with it and anyway would have made things more difficult carrying on without damaging it.
I have started by completing the Docking Lights first, which is proving to be more complicated than I thought it would be. With the boat being 1/7th scale it wasn't possible to buy ready made ones, the nearest available are 1/6th and much to big, also, I would have had to sell my car to afford them.
Following talking with Morosini Giovanni in Sarnico I was able to find out the dimensions of the full size lights so working out the 1/7th was straight forward.
After they are done the next step is making the bow protector which is 300mm long, things don't any easier, the Docking Lights are bad enough !!
A few pictures showing the progress made and it's to be painfully slow.
2365 shows the shiny finish completely sanded away.
2336 is the hole shaped finalised ready for the housing.
2363 shows the bits used to form the housing and outer frame, consisting of wooden male mould, the jig for milling the 2 Brass frames, the 0.4mm ply housing, and it's floor, finally the 2 frames.
Mike.
phillnjack3
« Reply #206 on: May 26, 2021, 03:12:29 am »
this isa very very special build for a very special boat, and looking great.
the varnish on the final is the big deal....
if it dont turn out like you realy want ill give you 50 quid for it and take it off your hands...
« Reply #207 on: May 26, 2021, 04:53:11 am »
Na......go back to September 2020, the finish is under contro:-))  .....
Looking forward to Project continuance Mike  O0
DJW
« Reply #208 on: May 26, 2021, 07:19:49 am »
Great to see the Riva back on the workbench Mike..!
Best regards
David.
ukmike
« Reply #209 on: May 31, 2021, 02:54:34 pm »
Hello.
More work started by making the Bow Protector and Docking Lights.
The pictures show them temporarily held in place to make sure all is o.k which seems that they look not too bad so I will tidy them up prior to Chroming.
Also  shown are pictures of how they should look as per the full size examples, alas, light years away from my efforts, I can't get anywhere near them but I'm reasonably
pleased with my attempts.
Mike.
Taranis
  • Balne Moor MBC
« Reply #210 on: May 31, 2021, 05:17:18 pm »
Yours looks better IMHO  :-))  The bow has a very strange way of showing a face with a different emotion depending how you see it.
Startled angry sad confused all in one image  :-)
ANDY
ukmike
« Reply #211 on: May 31, 2021, 05:26:52 pm »
Hi Andy.
Having had a look I have to agree.
Hopefully it will improve when some of the Mahogany is hidden under the White bottom.
Mike.
Mark T
« Reply #212 on: May 31, 2021, 06:14:36 pm »
Beautiful work Mike it really doesn't get better than that  :-))
« Reply #213 on: May 31, 2021, 06:37:13 pm »
Incredible work Mike (me who is throwing away his wood working tools now) congratulations  :-))
ukmike
« Reply #214 on: June 03, 2021, 07:03:28 pm »
Most of the deck fittings completed now, I dread to think the cost of all that Chroming.
After several attempts making the 4 scale engine room vents I have finally given up and used the same shape as Riva used on the last few Specials for the foredeck flagstaff/white/hooter/white running light all in one assy. Just a few bits and bobs to complete and then start searching for quotes fir the plating.
The photos show everything so far but just roughly in place and not yet fitted. The windscreen needs the final shaping then I can apply the green tint.
Mike.
ukmike
« Reply #215 on: June 16, 2021, 02:22:23 pm »
Good Afternoon all.
Very little done to the boat recently but I was able to make the flanges for the water and fuel fillers today.
My be of interest to see the drilling method for 5 symmetrically spaced holes, 1.5mm each.
A couple of pictures.
Mike.
« Reply #216 on: June 17, 2021, 01:22:45 am »
Hullo Mike.....5 bolt pattern is very common for wheel mountings, however not so popular for fluid sealing flanges .....with 3, 4 or 6 is near universal for this purpose
I can only think the 5 bolt propriety flanges for the Riva is as clearance or access issue .......is the 5th bolt located centrally at the top? ...if so, 2 will be located in the horizontal plane & marginally higher than for a 6 bolt pattern
Did the originals have synthetic gasketing?......so, what will you choose for the water?
ukmike
« Reply #217 on: June 17, 2021, 01:26:01 pm »
G'day Derek.
Over the years that the Aquarama was in production there were several changes to the design of the fuel/water fillers.
Some of the early ones were almost flush to the deck with no fixing shown as the fixings were done from the inside, Riva usually preferred not to show fixings to as
much of the deck furniture as possible. Later in the production, especially with the introduction of the "Special" version, the flush versions were changed to the
larger Mushroom design  there were 3 versions that I know of, all of which had flanges with external fixings but they varied in height and diameter.
I have made some of each type and have settled on the Mushroom design, but I have altered the diameter and height so that it looks right on my model.
Rightly or wrongly I preferred the 5 bolt flange fixing, so that is what it will have, after all, my model isn't perfect scale, far from it, also, some parts cannot be scaled to
1/7th ish, they would look silly and I try to avoid silly where possible.
The previous post was intended purely show how I achieved perfect hole spacing.
Thank you very much for the technical information tho', but fortunately not needed in this case, maybe in the future.
Mike.
ukmike
« Reply #218 on: July 01, 2021, 02:09:33 pm »
Hi.
Just about the last parts of the deck furniture made now.
2 fillers with flanges, Petrol and potable Water, along with the Stern Light which will have it's lens fitted after Chroming.
The Stern Light shape isn't much like the full size due to me not being skillful enough to reproduce it in miniature, but I don't think it looks too bad.
The pieces shown took me 11 hours to make including disasters, of which there were several.
Here are some photos.
Mike.
DJW
« Reply #219 on: July 01, 2021, 03:59:16 pm »
Looks pretty fine work to me Mike, and even better when chromed, well worth the effort.  :-))
ukmike
« Reply #220 on: September 12, 2022, 04:45:27 pm »
Good afternoon.
At last, Bigish Riva back on the work bench, first time since 2021. Have totally forgotten at what stage I was at, let alone finding the parts that I had made.
Have sanded the hull again in readiness for the final varnish and have decided to use a different varnish and not the LeTonk. due to the fact that, firstly, the can that I have is well out of date, that and the fact that it is now produced in Germany and apparently it is changed somewhat.
I never gave a thought to the chance of water getting into the boat, especially when going backwards (astern) or when stopping quickly from high speed as a stern wave
could climb some way up the bathing slide so I've solved the problem by fitting a plastic barrier which is gasketed all round making it completely watertight.
The upholstered slide its self remains the same.
Some photo's
Mike.
« Reply #221 on: September 12, 2022, 04:51:57 pm »
It's good to see her back on the bench Mike and more updates when you get yourself orientated.  :-)
DJW
« Reply #222 on: September 12, 2022, 05:17:20 pm »
Agreed..!  Great to see the Aquarama back on the bench Mike..!
Best regards
David.
DJW
« Reply #223 on: September 13, 2022, 01:50:49 pm »
Hi Mike
I meant to ask, what varnish are you planning to go with over the current Le Tonk..?
Best regards
David.
ukmike
« Reply #224 on: September 13, 2022, 03:22:21 pm »
Good afternoon David.
I wondered how long it would be before that question was posted. :-)
I thought that I would try it firstto see if it was any good before I told you.
Have applied 1 coat today by brush so see if it levels O.K. that was only 1 hour ago so it will be tomorrow until I know.
From the first look it seams that another coat will be needed, but tomorrow will decide that.
Will let you know.
Mike.
Pages: 1 2 3 4 5 6 7 8 [9] 10   Go Up
Page created in 0.096 seconds with 22 queries.
